Intruder detect with PIC, any idea ?
Goto page Previous  1, 2
PostPosted: Fri Sep 02, 2005 3:29 pm     Reply with quote
The 'supercap' solution, is only the way to go, provided the unit is going to have power at reasonably regular intervals. Most have a self discharge to approx 50% voltage, in about one month. Also remember that because of the linear discharge characteristic much less of the stored energy can actually be used. They are great devices for 'short term' storage, but not for long standby periods.
I think Asmallri's solution, with a small lithium battery, and a FET switch bypassing a mechanical switch, is probably about the simplest, and likely to work the best. Use a PIC that supports multiple oscillator speeds, so it an wake up using an internal RC oscillator at perhaps 32KHz, to store the details, and the life could be massive.
Page 2 of 2
