Posted: Tue Jun 07, 2005 6:43 am |
The watchdog does not care about what the processor is actually 'doing'. The only thing it cares about is the reset_wdt instruction. If you have this inside the loop, then the watchdog will never occur, but if (for instance), you have a layout like:
while (true) {
reset_wdt();
some_sort_of_loop;
Then if the 'some sort of loop' gets hung, the code will never return to the reset_wdt instruction, and will reset itself when the watchdog timer expires.
What sort of interval to choose, is entirely down to you. If your system is in a slow loop that may take many tens of mSec to execute, and you are happy to accept many mSec of delay before a fault is 'seen', then you can set the watchog out to a couple of seconds. However if you expect data every few uSec, and want a fast response if the sysem hangs, then going down to the minimum becomes the correct solution...
global
Posted: Fri Aug 26, 2005 6:09 am |
thanks a lot for all your help.
I worked it out but i still have one problem: i would like to to reset the PIC after 30 seconds if one condition is not satisfied.
I see that i can't have more than few seconds ,with the watchdog.
How could i manage this for 30 seconds ?
Is there a big difference between setup_wdt(WDT_ON), that restarts the PIC, and the reset_cpu() function that i think is doing the same thing ?
So i can reset the pic when i decide it right ?
Is it the same reset for the PIC or not ?
Many thanks. |
global
Posted: Mon Aug 29, 2005 12:45 am |
asmallri
Joined: 12 Aug 2004 Posts: 1679 Location: Perth, Australia
Posted: Mon Aug 29, 2005 10:41 pm |
| Quote: |
A WDT is typically used to to recover from unexpected program behaviour such as a program crash. In you case you do NOT need the WDT.
Initial a timer for a 30 second count();
do
do something();
if (my event occured)
disable timer;
if (timer expired)
reset_cpu);
| Quote: |
These funcition are not even related. reset_cpu() means perform an immediate rest of the CPU.
setup_wdt(WDT_ON) means enable the software enabled WDT logic. Once you enable the WDT logic, if you do not periodically restart_wdt() then eventually the WDT timer will expire and the processor will reset. _________________ Regards, Andrew
asmallri
Posted: Mon Aug 29, 2005 10:44 pm |
| Quote: |
do
do something();
disable timer;
if (timer expired)
reset_cpu);
| Quote: |
global
Posted: Tue Aug 30, 2005 3:01 am |
Many thanks for you answer !
Do you have an exemple that shows how you do that ?
I want to count 30 seconds with a timer but i don't know how to use it this way and to disable the timer.
Do you have a concrete example for me to use a timer on a pic 18F458 at 4 MHz that count 30 seconds or more but not disturbing what the main is doing?
Many thanks. |
asmallri
Posted: Fri Sep 02, 2005 10:20 am |
There's no free lunch. Here is a sample, based on a method I commonly use.
// System Timer 1ms clock
#define C_TMR0_1ms 256 - (XTAL_FREQ/(64*4*1000))
int8 TMR_100ms; // 100ms timer counter
int16 TMR_30sec; // 30sec timer counter
short some_condition; // some flag or other....
void ServiceSystemTimer()
// Subroutine ServiceSystemTimer
// Tests the interrupt flag for the system timer (Timer 0)
// On Exit:
// TF_100ms set (TRUE) when TMR_100 decrements to 0
// TF_30sec set (TRUE) when TMR_30sec decrements to 0
// Calls:
// timer 0 interrupt source?
if (bit_test(INTCON, TMR0IF))
// here on timer 0 rollover
// reset the count for Timer 0
TMR0L += C_TMR0_1ms;
clear_interrupt(INT_Timer0);
// service the 100ms timer
if(!--TMR_100ms)
TF_100ms = TRUE;
TMR_100ms = 100;
// service the 30sec timer if active
if(some_condition && (!--TMR_30sec))
TF_30sec = TRUE;
TMR_30sec = 300;
void do_something()
// some condition has occured where I want to start the 30 second timer
some_condition = true;
TMR_30sec = 300;
TF_30sec = false;
main
// initialise 100ms supervisor timer
TMR_100ms = 100;
TF_100ms = false;
// initialise 30sec timer
TMR_30sec = 300;
TF_30sec = false;
some_condition = false;
// setup the timers
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_64 | RTCC_8_BIT);
while (1)
do_someting();
ServiceSystemTimer();
if (some_condition && TF_30sec)
reset_cpu();
