Wouhou Guest
Led flickering and functions ... |
Posted: Wed Aug 24, 2005 7:47 am |
i am using a pic 18F458 with ccs 3.206.
What i wanted to do is to switch on and off a led to make it flicker that shows that a device is switched on.
But the device should wait for data and execute a command.
So i tried to do that with an interrupt but it is not working ...
Code: | #define HIGH_START 114
byte seconds, high_count;
#INT_RTCC
clock_isr() {
if(--high_count==0) {
output_high(PIN_B0);
delay_us(5);
output_low(PIN_B0);
high_count=HIGH_START;
main() {
set_rtcc(0);
setup_counters(RTCC_INTERNAL, RTCC_DIV_64);
enable_interrupts(INT_RTCC);
// do something;
where should i put this Code: | high_count=HIGH_START; |
to make an overflow ? Everywhere that i have a new while ? Because i have lots of while in my while :p
Any ideas ?
Thanks |
sseidman
Posted: Wed Aug 24, 2005 8:15 am |
Five microseconds is MUCH TOO SHORT to be able to see an LED flicker on. Try 100 milliseconds.
It's not a great idea to be hanging out in an interrupt routine for 100 ms, depending on what else you want your program to do. If you have a second timer available, its much better to use one timer, like you're doing, to set the frequency of the LED. That interrupt should turn the bit on, and start a second timer that controls the duration of the LED on time. When that interrupt triggers, turn the LED bit off, and stop the duration timer.
Scott |
sseidman
Posted: Wed Aug 24, 2005 8:27 am |
Aah--
I see what you're trying to do now. It doesn't make any sense the way you're looping. Pin B0 is going to go high for 5microseconds, and then low for a few instruction cycles, and then high again.
Also, somewhere in main, make sure you define pin B0 as an output.
Place HIGH_START into your counter
set_timer0(HIGH_START);
So:
Code: | #INT_RTCC
clock_isr() {
delay_ms(50);
output_low(PIN_B0);
set_timer0(HIGH_START); //there are more accurate ways to do this
It's hard to know if the timing is right without knowing your clock frequency. You probably want to blink the LED for 50-100ms every 2 seconds or so.
But consider using one interrupt for frequency, and one for duration, as discussed before. |
Humberto
Posted: Wed Aug 24, 2005 8:52 am |
byte high_count;
#INT_RTCC
clock_isr() {
high_count--;
if(!high_count)
output_toggle(PIN_B0);
main() {
set_rtcc(0);
// do something;
Humberto |
Wouhou Guest
Posted: Thu Aug 25, 2005 1:45 am |
Thanks for your responses :
could you tell me how to do this ? Using 2 interrupts please ?
I don't really sure to understand.
Humberto your programm is not working i don't know why ... |
Wouhou Guest
Posted: Thu Aug 25, 2005 3:06 am |
If i try to it this way in the interrupt :
Code: | counter =0;
#INT_RTCC
clock_isr() {
if(system_on)
if(counter == 0) {output_high(LED);}
if(counter == 10) {output_low(LED); counter = 0;}
counter++;
It is better to not use a delay, so i tried this way but it is not accurate, could you tell me why ? |
Wouhou Guest
Posted: Thu Aug 25, 2005 3:07 am |
Maybe it is better if you could tell me how to use 2 interrupts i think it will be the better way to do it !
HELP ! |
Posted: Thu Aug 25, 2005 5:08 am |
Wouhou wrote: | If i try to it this way in the interrupt :
Code: | counter =0;
#INT_RTCC
clock_isr() {
if(system_on)
counter++;
It is better to not use a delay, so i tried this way but it is not accurate, could you tell me why ? | What do you mean with 'not accurate'?
It will only work for the first cycle and then fail. When counter reaches 10 you reset counter to 0 but then immediately add 1, so the next times you enter the interrupt the test for 0 will always fail. |
Wouhou Guest
Posted: Thu Aug 25, 2005 5:42 am |
Ok ! Thanks for that !
I fixed it out but the led is switched on and off too long.
I tried this :
counter++;
if(counter == 1) {output_high(LED);}
if(counter == 2) {output_low(LED); counter = 0;} |
Do ou know how i could do this but to have something like this for 50-100ms every 2 seconds or so ?
i putted counter as an int. How can i do ?
Many thanks. |
Posted: Thu Aug 25, 2005 6:51 am |
Given the clock frequency of your CPU you can calculate the timing for the timer0 interrupt: Code: | interrupts per second = Clock freq. / (4 x prescaler x counter max.) |
with Code: | setup_counters(RTCC_INTERNAL, RTCC_DIV_64); | the timer is setup with a prescaler that divides by 64 and the interrupt fires when the counter overflows (at 256 for an 8 bit counter).
You didn't tell us your clock frequency, but let's assume it is 4MHz, then you get the following calculation: Code: | interrupts per second = 4MHz / (4 x 64 x 256) = 61 times per second |
Change your code then to Code: | #define TWO_SECONDS (2 * 61)
#define MSEC_100 (6)
counter++;
if (counter == TWO_SECONDS) {output_high(LED);}
if (counter == (TWO_SECONDS + MSEC_100) {output_low(LED); counter = 0;} |
Wouhou Guest
Posted: Thu Aug 25, 2005 8:11 am |
Ok many thanks ! |
Humberto
Posted: Thu Aug 25, 2005 12:07 pm |
Wouhou wrote:
For your info the code I posted is right and tested.
The code is pretty simple. I used 16F628 and 8Mhz crystal and I get in the scope a
clear and symetrical toggling in PINB0 every 930ms.
Check your hardware, tools and test procedure.
Humberto |
Bart
Posted: Thu Aug 25, 2005 2:38 pm |
Hello Humberto or Wouhou,
Can you explain me how you come to, our how you calculated, the 114 value ? (Can you eventualy use 20 Mhz as clockspeed as example calculation ?)
Thanks.
_________________ I like Skype (www.skype.com), my username is BplotM |
Humberto
Posted: Thu Aug 25, 2005 3:33 pm |
It doesn´t have any special meaning, it is a constant value assigned in compilation time
to the preprocessor identifier HIGH_START using the preprocessor directive #define
In the posted code it is used to reload a decremented counter when it reach zero.
In the statement
if(--high_count==0)
high_count is decremented and tested if it is = 0.
If high_count==0 it is loaded with the value 114, wich is replaced
using the identifier HIGH_START to repeat the cycle.
Yes of course. (assuming you are talking about ckielstra example calculation)
Read this excelent thread posted by newguy:
http://www.ccsinfo.com/forum/viewtopic.php?t=22467
Humberto |
