macgyver
| string parsing |
Posted: Wed Aug 24, 2005 5:49 am |
hi.
from a PC to a PIC i am looking to take in a string of data which will look simlar to X17264 Y74747 Z78689 or the letters at the end of the numbers if it's easier, but what i need is to be able to take the numbers out an put them into the appropiate variable namely X,Y and Z. anyone have an idea as to how to do it, bare in mind i am no programmer, the rest of my code works fine but doing this is over my head.
thanks. |
Mark
Posted: Wed Aug 24, 2005 6:25 am |
Take a look at this:
http://www.ccsinfo.com/forum/viewtopic.php?t=20225&highlight=sscanf
Another approach would be to look at each character. If you find an X, then start reading each char verifying that its a number. When you find one that is not, convert the values read into a number.
Here some untested code for you
int8 getnumber(char* Buf, int8 index, long* retval)
char number[10];
int8 i;
// Look for digits
i = 0;
while (isdigit(Buf[index]) && i< (sizeof(number)-1))
// Store the digits into a temp array
number[i] = Buf[index];
i++;
index++;
// terminate the string
number[i] = 0;
*retval = atol(number);
// return the new position in the array
return(index);
#define BUF_SIZE 25
char buf[BUF_SIZE]={"X17264 Y74747 Z78689"};
long x,y,z;
int8 i;
for (i=0;i<BUF_SIZE;i++)
if (buf[i] == 'X')
i++;
i = getnumber(buf,i, &x);
else if (buf[i] == 'Y')
i++;
i = getnumber(buf,i, &y);
else if (buf[i] == 'Z')
i++;
i = getnumber(buf,i, &z);
