Driver for TC72 Temperature Sensor
newpic
PostPosted: Thu Aug 18, 2005 2:41 pm     Reply with quote
Anyone has a driver for the Microchip TC72 device?
Please help....
Thanks...
dyeatman
TC72 Driver Info
PostPosted: Thu Aug 18, 2005 3:12 pm     Reply with quote
Try the Microchip AN940 and accompanying source code for information on how a driver should be built.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en020348
http://ww1.microchip.com/downloads/en/AppNotes/00940A%20Source%20Code.zip
Here is some C Source for the TC77 that might help...
http://forum.microchip.com/attachment.asp?m=103923
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Thu Aug 18, 2005 3:41 pm     Reply with quote
#include <16F876.h>
#device ADC=10
#use delay(clock=4000000) /* one instruction=1us? */
#use I2C(master, SCL=PIN_C3, SDA=PIN_C4)
            int data;
            int ack;
            long int fahr;
    printf ("\r\n\r\n\r\n");
    printf ("T C 7 2   D E M O\r\n");
    while (1)
         i2c_start();
         ack = i2c_write(0x9A);
        ack = i2c_write(0x00);
        /* send start again */
        i2c_start();
        ack = i2c_write(0x9b);
        data = i2c_read();
        i2c_stop();
        fahr = (9 * (long)data);
        fahr = fahr/5;
        fahr = fahr + 32;
        printf ("Temp: %ld\r\n", fahr);
        delay_ms(200);
PostPosted: Thu Aug 18, 2005 3:55 pm     Reply with quote
while (1)
i2c_start();
TC72 is a SPI chip, not i2c.
http://www.microchip.com/stellent/idcplgidcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010748
MikeValencia
PostPosted: Thu Aug 18, 2005 4:09 pm     Reply with quote
oops. I cut and pasted code that i once wrote for the PICDEM. And i added some printf's in there. Looking at the schematic i realize now it is a TC74.
Why don't you just use a TC77 or a TC74. The code is here.
dyeatman
PostPosted: Thu Aug 18, 2005 4:13 pm     Reply with quote
Just think how much will be learned if they use the Microchip info and develops a driver instead of having someone else do all the work... I have been forced to write written custom drivers 10-12 times now and have gotten pretty good at it. Not so hard with a little practice...
newpic
TC72 Help
PostPosted: Fri Aug 19, 2005 8:11 am     Reply with quote
Can any body look at my code, why it does not work. Do I need to have the driver or not?
Thanks in advanced.
#include <16F876A.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#define clk      pin_c3                   // set pin clock is using
#define din      pin_c5                   // set pin data in is using
#define cs       pin_b2                   // set pin load/cs is using
int16 temp1;
    output_low(clk);                      // set clk line low
      delay_us(1);
    output_low(din);                      // set data line in low
      delay_us(1);
    output_low(cs);                       // set load/cs line high
      delay_us(1);
     setup_adc_ports(NO_ANALOGS);
     // Configure TC72 temperature sensor
     setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_XMIT_L_TO_H | SPI_CLK_DIV_16);
      output_high(cs);                     // set cs line high
      delay_us(1);
         spi_write(0x80);                 // Write Address
      delay_us(1);
      spi_write(0x00);             // Continuous mode
      delay_ms(150);                // Delay 150ms to let it complete conversion
      spi_write(0x02);              // Point to MSB temp register
      delay_us(1);
        temp1=spi_read(0);                // read temp
       delay_us(1);
      output_low(cs);
      printf("Temperature is: %lu\n\r",temp1);
Re: TC72 Help
PostPosted: Fri Aug 19, 2005 9:49 am     Reply with quote
Actually, your spi_write() and read functions are the "driver".
PostPosted: Fri Aug 19, 2005 9:52 am     Reply with quote
It always display
"Temperature is: 0 "
It does not get the right temperature data with the above code.
Did I do anything wrong in the code?
PostPosted: Fri Aug 19, 2005 11:15 am     Reply with quote
If you see icicles in the room, then I guess you did it right.
