Serial Port, Can I do this?
ljbeng
PostPosted: Tue Aug 16, 2005 9:59 am     Reply with quote
I want the received characters to buffer in the RDA interrupt. Receive will always be 9600 baud.
But I want complete control over the transmit characters in software. Will this do it?
I don't want to use the SET_UART_SPEED command....
PIC18F452
I took only snippets to show here so this program may not compile.....
#define rsxmt PIN_C6
#define rs9600 PIN_B3
#use rs232(baud=9600,parity=N,rcv=PIN_C7,bits=8,errors)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,bits=8,force_sw)
#int_RDA
RDA_isr(){
gotpoll = 0;
rt = 0;
rcin = getc();
bytcnt++;
if (bytcnt <= buffer) rcvbuff[bytcnt] = rcin;
void rs232putc(int inp){
int rot,par;
   if (!input(rs9600)) putc(inp); //tx at 9600 baud
   else {//transmit manually at 300 baud odd parity
      output_low(rsxmt);
      delay_us(3333);
      par = 0;
      for (rot = 1; (rot !=0) && (rot <= 128); rot = rot * 2){
         if (inp & rot) output_high(rsxmt);
         else output_low(rsxmt);
         if (inp & rot) par++;
         delay_us(3333);
      par++;
      if (bit_test(par,0)) output_high(rsxmt);
      delay_us(3333);
      output_high(rsxmt);
      delay_us(3333);
void main(){
   enable_interrupts(INT_RDA);
while(1){
   rs232putc(0xA);
PostPosted: Tue Aug 16, 2005 10:28 am     Reply with quote
You can't split the hardware UART into a hardware part and a software
part. That is because of a hardware limitation of the PIC, not CCS.
You must either have a full hardware UART or a full software UART.
These two lines will create two software UARTs:
ljbeng
PostPosted: Tue Aug 16, 2005 10:44 am     Reply with quote
Thanks. I think I will just move my transmit pin somewhere else for a software (my own) UART and use the hardware UART for receive and PIN_C6 will be open...
