Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
array or string use
RTURNPAUGH
array or string use
PostPosted: Sat Jan 04, 2003 8:03 pm     Reply with quote
I am trying to make a key code device. I want to be able to store a PIN in eeprom and read a PIN from the keypad to compare against. Does anyone have a sample piece of code for writing a string to eeprom?
___________________________
Original Post ID: 10422
john cutler
Re: array or string use
PostPosted: Sun Jan 05, 2003 1:26 pm     Reply with quote
:=I am trying to make a key code device. I want to be able to store a PIN in eeprom and read a PIN from the keypad to compare against. Does anyone have a sample piece of code for writing a string to eeprom?
Check out th CCS F.A.Q. on their page. They have an example for floating pt numbers which seems to me would be "easy" to covert to your purposes.
Good luck!
Original Post ID: 10431
RTURNPAUGH
PostPosted: Sun Jan 05, 2003 5:12 pm     Reply with quote
:=:=I am trying to make a key code device. I want to be able to store a PIN in eeprom and read a PIN from the keypad to compare against. Does anyone have a sample piece of code for writing a string to eeprom?
:=Check out th CCS F.A.Q. on their page. They have an example for floating pt numbers which seems to me would be "easy" to covert to your purposes.
:=Good luck!
:=Thanks for the info. That's exactly what I was looking for.
Original Post ID: 10438
