Pre-processor expansion problem
asmallri
PostPosted: Fri Jul 15, 2005 10:20 pm     Reply with quote
PCH 3.228 - PIC18F1320
With the following defines:
#define LATA 0x0F89
#define LED_Status   LATA, 4   // status LED - low to illumuniate
#define bit_toggle(my_port, my_bit) {#asm  btg  my_port, my_bit  #endasm}
This compiles sucessfully:
      bit_toggle(LATA, 4);
The following give a: *** Error 95 "xxx.c" Line 26(23,24): Expecting an opcode mnemonic
      bit_toggle(LED_Status);
I have previoulsy nested defines but with a single level (1:1) substitution. What am I doing wrong?
Thanks..
Regards, Andrew
PostPosted: Sat Jul 16, 2005 12:07 am     Reply with quote
Did you know that CCS has a toggle function ?
Here's the .LST file. It's setting the TRIS, but that's because I'm
using Standard i/o. If you use Fast i/o mode, then it just does
the BTG instruction.
.................... output_toggle(PIN_A4);
0020:  BCF    F92.4
0022:  BTG    F89.4
asmallri
PostPosted: Sat Jul 16, 2005 12:25 am     Reply with quote
Thanks - I did not realise this function worked on the LAT, I thought it operated directly on the port.
I would still like to know how to do the nested precompiler substitution.
Regards, Andrew
bb
PostPosted: Sat Jul 16, 2005 1:27 am     Reply with quote
Hi Andrew,
The problem is the comment.
The line
gets expanded by the preprocessor to:
bit_toggle(0x0F89, 4  // status LED - low to illumuniate);
When using a comment in the same line as '#define', you'll have to do it this way:
#define LED_Status   LATA, 4   /* status LED - low to illumuniate */
Best regards,
Bernd
asmallri
PostPosted: Sat Jul 16, 2005 2:32 am     Reply with quote
Thanks Bernd but that did not work either. even removing the comment completely from the line did not work.
Regards, Andrew
Regards, Andrew
bb
PostPosted: Sat Jul 16, 2005 4:49 am     Reply with quote
Try
#define LATA 0x0F89
#define bit_toggle(my_bit) {#asm  btg  my_bit  #endasm}
bit_toggle (LED_Status);
Best regards,
Bernd
asmallri
PostPosted: Sat Jul 16, 2005 7:17 am     Reply with quote
I tried it for interest and it did work. However I specifically want to be able to specify addreeses and bits separately in the call.
Thanks, Andrew
Regards, Andrew
bb
PostPosted: Sat Jul 16, 2005 7:56 am     Reply with quote
I don't think that this is possible when using a single '#define' for both arguments.
When a function macro is being processed, the steps are as follows:
1. All of its arguments are identified.
2. Except in the cases listed in item 3 below, if any of the tokens in an argument are themselves candidates for macro replacement, the replacement is done until no further replacement is possible. If this introduces commas into the argument list, there is no danger of the macro suddenly seeming to have a different number of arguments; the arguments are only determined in the step above.
3. In the macro replacement text, identifiers naming one of the macro formal arguments are replaced by the (by now expanded) token sequence supplied as the actual argument. The replacement is suppressed only if the identifier is preceded by one of # or ##, or followed by ##.
The C book, chapter 7.3.2.1
The arguments of the function macro are identified first. Therefore 'LED_Status' is treated as one argument (the comma is meaningless) and the macro misses the second argument.
Best regards,
Bernd
kam
The White Book
PostPosted: Sat Jul 16, 2005 4:53 pm     Reply with quote
Thanks Bernd for the complete explanation. What I got out of it was very interesting...
I am re-entering the "chip programming" world after many years of PC (Intel, Motorola) programming (so everyone watchout for questions!!! Razz ). I remember reading The White Book or K&R etc etc etc (boring stuff removed! Shocked ). But after all these years I just assumed that the compiler makers would "fix" or allow for a "fix" in there compilers. I just assumed that the compiler maker would have at least given a warning or something. I can imagine the head scrathing I would have done if I did not know that they are 100% K&R in the above question. So for any bizzar problems the best initial approach is the check out the asm and see what the compiler did and make sure it did that I thought! God what an pain! They need a "MAKE-IT-ANSI-2005-AND-ISSUE-WARNINGS-TO-HELP-THE-PROGRAMMER" switch! Razz Razz Razz
But again, thanks for the complete answer!
~Kam (^8*
