RS232 HELP- using Hyperterminal
Goto page Previous  1, 2
Mark
Re: reply
PostPosted: Tue Jul 05, 2005 8:29 am     Reply with quote
Sophi wrote:
Thanks Humberto-
Yes I read everything in the forum - that's how I chose all my settings for Hyperterminal!
I am using a Protoboard (Olimex) that comes with a MAX232 chip. I've connected TX from the MAX232 to PIC- C6 and RX from MAX232 to PIC C7. I'm using a PIC16C74A.
Any advice is appreciated!
Sophi
This is your problem. Take a look at the schematic
http://www.olimex.com/dev/images/pic-p40b-sch.gif
They have Rx going to T2in. This is not Rx of the PIC but rather the Rx signal of the other device. You should have this connected to Tx (C6) of the pic and Tx should be connected to Rx (C7) of the pic.
Sophi
PostPosted: Tue Jul 05, 2005 8:51 am     Reply with quote
thanks Mark-!
Now pin C6 and C7 are high but still nothing from Hyperterm. Is there something else I need for the settings? Should the received words just come up on the screen or do I need to "ask" HT for it?
Sophi
Mark
PostPosted: Tue Jul 05, 2005 8:54 am     Reply with quote
According to the schematic, you should not be using a Null cable.
Humberto
PostPosted: Tue Jul 05, 2005 9:16 am     Reply with quote
The previous code I post was just to know if your hardware was running.
To get some "burst" with a scope you need a code like this:
#include <16c74a.H>
#fuses HS,NOPROTECT,NOWDT,NOBROWNOUT,PUT
#use delay(clock=20000000) // adjust for resonator frequency
main()
  setup_adc_ports(NO_ANALOGS); // sets port A all digital
  do
     output_toggle(PIN_A0);
     printf("1234567890");
    }while(1);
Be aware that you must change your scope trigger setup to the levels you will find in figure
"One byte of async data" in this link:
http://www.arcelect.com/rs232.htm
and connecting your scope in the DB9 pin 3 (RS232 Tx) you would "see" the output
signals string every 100 msec.
Keep well,
Humberto
Sophi
PostPosted: Tue Jul 05, 2005 9:34 am     Reply with quote
My PIC speaks to HTerm!
No NULL cable-
Switched TX and RX wires...Thanks!
Mark- I am looking at my schematic and I would never have figured that out from it, what do you see on there that says RX and TX do not go to PIC? And how would I know for future about using NULL or not?
Now to work out how to speak to my PIC from HT....?
Sophi
Mark
PostPosted: Tue Jul 05, 2005 9:35 am     Reply with quote
Pin 2 is the output on the proto board.
Mark
PostPosted: Tue Jul 05, 2005 9:38 am     Reply with quote
No NULL cable-
Sophi
I looked at the MAX232 chip. Outputs should go to inputs and inputs should go to outputs. As far as the Null cable goes, if both devices have the same pin out then you will need the Null cable. You can find the pin out for a standard pc serial port on the net.
Humberto
PostPosted: Tue Jul 05, 2005 11:50 am     Reply with quote
Five days ago I suggested you to check this:
  PIC                       MAX232
 PIN_C6  >--------    Should be PIN 10 or 11
 PIN_C7  <--------    Should be PIN 12 or  9
and your answer was:
All is wired as it should be (Thanks Humberto!)
Question Question Question
I assume that check means hardware debug not simply reading a schematic.
Humberto
Sophi
PostPosted: Tue Jul 05, 2005 1:14 pm     Reply with quote
Yes I had switched the wires a couple of times- back and forth, trying everything. Now with no null cable plus right wiring and HT configured right, all is Smile
Thanks so much for all your help everyone-
Everything works great!
Sophi
Page 2 of 2
