densimitre
| Invert order/position of char on string?? |
Posted: Mon Jul 04, 2005 10:01 pm |
Hi
I need invert the char´s order on a string, like this:
string_1[]="ABCDEFGHIJ"
i need invert it to
string_2[]="BADCFEHGJI"
I dont know how make it ..
Thank you
asmallri
Joined: 12 Aug 2004 Posts: 1663 Location: Perth, Australia
Posted: Mon Jul 04, 2005 10:10 pm |
int i,j;
j = strlen(string_1);
string_2[j--] = 0;
for (i = 0; i < strlen(string_1); i++, j--)
string_2[j] = string_1[i];
_________________ Regards, Andrew
Posted: Tue Jul 05, 2005 1:09 am |
| asmallri wrote: | | Code: |
int i,j;
string_2[j--] = 0;
| This routine will invert the whole string to 'JIHGFEDCBA', it will not reverse just the pairs of characters as indicated by Densimitre.
I suggest something like:
| Code: | int8 i, len;
i = 0;
len = strlen(string_1);
while (i < len)
string_2[i] = string_1[i+1];
string_2[i+1] = string_1[i];
i += 2;
if (len % 2) // Special case handling for string with odd number of characters
string_2[len - 1] := string_1[len - 1];
string_2[len] = 0;
densimitre
Posted: Tue Jul 05, 2005 4:40 pm |
Thank you very much
If i have something like:
string_1[]="12345678]
and i want take 2 char together (12 , 34 , 56 , 78) and invert them to (21, 43,65,87) and grouping them but using only 1 byte in HEX format for each pair of numbers??
Thank you |
valemike Guest
Posted: Tue Jul 05, 2005 6:07 pm |
Starting at x=0,
look at char[x];
subtract 0x30 from it to get the units value.
look at char[x+1];
subtract 0x30 from it to get the tens value, and multiply that by 10.
This is your two-digit value. Add the two previous numbers you just finished computing.
Keep doing this til you get to the end of the array. And don't forget to increment your iterator x by 2 each time.
You could use some of those bcd or atoi or viceversa functions, but i forgot how to use them. |
densimitre
Posted: Tue Jul 05, 2005 11:02 pm |
Hi
Mmmmmm.....
Considering than ascii chart from 1 to 9 are 0x01 to 0x09 in hex format, I think something like this:
char_source[]="1,2,3,4,5,6,7,8"; // I need only numbers (does char_source contain a NULL char at end ????
char_dest[4]; // I need pack 2 ascii digit into 1 hex byte
int i=0;
while(i<=strlen(char_source) {
char_dest[i]= (char_source[i+1]<<4) || char_source[i]);
i=i+2;
the result must be:
char_source[]={0x21,0x43,0x65,0x87}
after this, i need printf char_source in hex format...
Thank you very much... |
densimitre
Posted: Wed Jul 06, 2005 11:28 am |
Hi
I add this code to print resukt in hex format:
| Code: | for (i=0;i<4;i++) {
printf("%X",char_dest[i]);
putc('\r');
putc('\n');
But the result is:
B9
B2
39
79
Mi code above ist not working....why?
Thankz
The result |
valemike Guest
Posted: Wed Jul 06, 2005 12:01 pm |
I wrote the code in a Unix machine. Use it as a reference. It's up to you to port it to the PIC, and up to you to code a loop to go thru to the end of the string:
"ccs.c" 20 lines, 408 characters
hawk:/usr2/student/v/valemic1>!gcc
gcc ccs.c -o ccs
ccs.c: In function `main':
ccs.c:5: warning: return type of `main' is not `int'
hawk:/usr2/student/v/valemic1>./ccs
1
2
my_number = 21
hawk:/usr2/student/v/valemic1>cat ccs.c
#include <stdio.h>
#include <unistd.h>
char mike[] = "123456789";
char *mike_ptr;
char *mike_ptr2;
int my_number;
mike_ptr = &mike[0];
mike_ptr2 = &mike[1];
printf ("%c\n", *mike_ptr);
printf ("%c\n", *mike_ptr2);
// Now generate an int.
my_number = (*mike_ptr2 - 0x30) * 10 + (*mike_ptr - 0x30);
printf ("my_number = %d\n", my_number);
1
2
my_number = 21
Posted: Wed Jul 06, 2005 4:39 pm |
| densimitre wrote: | Hi
putc('\r');
putc('\n');
But the result is:
B9
B2
39
79
Thankz | Several reasons:
1) | Quote: | | Considering than ascii chart from 1 to 9 are 0x01 to 0x09 in hex format, I think something like this: | The numbers 1 to 9 in the ASCII chart have a hex value of 0x30 to 0x39. Convert the ASCII digit to an integer digit by subtracting 0x30, or for better readability subtract by '0'.
2) | Code: | | char_source[]="1,2,3,4,5,6,7,8"; // I need only numbers (does char_source contain a NULL char at end ???? | This sequence also includes the ',' characters, you don't want to convert those.
Yes, the string contains a NULL character as well (but the returnvalue of strlen() does not include this).
3) | Code: | | while(i<=strlen(char_source) | This loop is iterating one time too many and is dangerous because it makes your code overwrite RAM after the end of the Dest[] array.
Also, calling strlen() in the while loop is not very efficient. The length of the string doesn't change, so you get a better performance by calling it just once before entering the loop.
4) | Code: | char_dest[i]= (char_source[i+1]<<4) || char_source[i]);
i=i+2; | You are increasing pointer i by 2, but for the destination string the pointer should be increased by just 1. This can be solved by introducing a second pointer.
This is how I changed your code:
| Code: | #include <string.h>
char Source[] = "12345678"; // I need only numbers (does char_source contain a NULL char at end ????
char Dest[4]; // I need pack 2 ascii digit into 1 hex byte
int8 i,j;
int8 Len;
i = 0;
j = 0;
Len = strlen(Source);
while (i<Len)
Dest[j] = ((Source[i+1] - '0') * 10) + (Source[i] - '0');
i += 2;
j++;
for (i=0; i<4; i++)
printf("%X\r\n", Dest[i]);
while(1); // Prevent the program from executing the sleep
// instruction at the program end or the printf
// will not get enough time to output all data.
And it will print:
0x15 (decimal 21)
0x2B (decimal 43)
0x41 (decimal 65)
0x57 (decimal 87)
Is this the output you expected? Or did you intend the input string to be hexadecimal instead of decimal? |
densimitre
Posted: Wed Jul 06, 2005 8:03 pm |
Hi
mi new code:
#include <16f648a.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,MCLR,NOLVP
#use RS232(BAUD=9600, BITS=8, PARITY=N, XMIT=PIN_B2, RCV=PIN_B1, stream=r520,errors)
#include <string.h>
char char_source[]="12345678";
char char_dest[4];
void main(void) {
int i=0, j=0;
printf("String_Source: %s\n\r",char_source);
while(i<4) {
//while(i<=strlen(char_source)) {
char_dest[i]= (char_source[j+1] -0x30)*10 + (char_source[j] -0x30) ;
printf("%d",char_dest[i]);
i=i+1;
j+=2;
The result is:
Source_dest: 21436587
MikeValencia
Posted: Wed Jul 06, 2005 9:39 pm |
Are you asking if it is correct or not?
Yes and no.
Yes: The computed results are correct.
No: You forgot to put the "\r\n". Of course it's going to be a big number
Out of curiosity, what application is this for? |
densimitre
Posted: Wed Jul 06, 2005 10:38 pm |
Ok
Well, first thank to all of you for great help...WOW !!!!!
My project is send a SMS in PDU mode, with CSA =0x00 (CSA data storen in phone).....In the destination number, if type number is 0xA1 (national/idsn), the leng of number is 8, but showed in 4 byte in hex format: here is my issue....the number is inverted.....92347583 must be: 29435738.....I can put it in the frame in that order, but the idea is a changing dest number by choices.......
I dont still try in my PIC, but a will stay inform toy you about it..
Thank you |
densimitre
Posted: Thu Jul 07, 2005 9:38 pm |
Hi
I found this code
void hexout(byte daten)
byte help;
help=daten>>4; // das höherwertige Nibble
if(help > 9)
help+=7;
printf("%c", help + '0');
help=daten & 0x0F; // das niederwertige Nibble
if(help > 9)
help+=7;
I need use it with a string as argument, in order to hexout a full string, to past it in the user data field of sms
Bye |
Posted: Fri Jul 08, 2005 2:11 am |
| Quote: | | Code: |
byte help;
if(help > 9)
help+=7;
if(help > 9)
help+=7;
This whole function can be simplified to:
| Code: | void hexout(byte data)
printf("%2X", data);
| Quote: | | I need use it with a string as argument, in order to hexout a full string, to past it in the user data field of sms | I don't understand this, can you be a bit more specific? What is your question?
Higher up in this thread you already created a function for integer_string[8] --> bcd[4].
The function you are giving us now is doing the reverse for a single byte. Is that what you want, but now for a whole string?
Is the string zero terminated?
Has the string a fixed length of 4 like in your previous code?
Do the digits have to be swapped like in your previous code?
The binary format you are converting to is commonly known as BCD (Binary Coded Digit), searching this forum I'm sure you will find several conversion routines. |
densimitre
Posted: Fri Jul 08, 2005 8:09 am |
| ckielstra wrote: | | Quote: | | Code: |
byte help;
if(help > 9)
help+=7;
if(help > 9)
help+=7;
ckielstra, master, you are right:
I made this code, and ist working for me:
char char_text[]="hellohello"
int len;i;
len=strlen(char_text);
printf("%d\n\r",len); //10 fot this test
for (i=0;i<len;i++) {
printf("%2X",char_text[i]);
The output is: 68656C6C6F68656C6F6F.
Thats is i need, thank you so much.... |
