Paul Smith Guest
Bit Stuffing & shifting |
Posted: Sat Jul 02, 2005 11:20 pm |
Hi all.
Perhaps some of you know how to do this.
Is it possible to have such a thing as a variable that is 14 bits wide only
and then copy say a 8 bit variable into the 14 bit wide variable.
The reason I ask is that I have to load a shift register with data.
Its a pll. One of the registers is a total of 14 bits wide. But I will
never use the full 14 bits. Typically I use only 7 bits in various combinations.
When loading the pll it expects to see the full 14 bits so the load sequence
is correct.
A code snip or insight would be helpful to me.
Thanks Paul. |
Posted: Sun Jul 03, 2005 2:29 am |
No, but yes!...
Basically, a variable inside the C, will always be a mutliple of 8 bits wide. However there is nothing at all to prevent you using just 14bits of a 16bit variable.
So, you can do something like this:
void output_14(int8 val) {
int16 big_val;
int8 count;
big_val=(int16)val;
//This 'casts' the 8bit value 'up to 16bits long
for (count=0;count<14;count++) {
if (bit_test(big_val,count)) {
//Here the bit is high, so do what you want with it
else {
//Here the bit is low
This goes through fourteeen bits, containing the eight bit value 'val' as the eight least significant bits, working LSB first (count the other way if you want MSB first), and you then need to output the data as required in the two branches.
