GoldServe
Posted: Thu Jun 30, 2005 8:25 pm |
| ckielstra wrote: | Which compiler version are you using?
I compiled your first version in v3.226 and the configuration looks ok. I don't have the hardware so couldn't confirm a correct timing. |
I'm using compiler version 3.200
| Quote: | | This is strange, why is the voltage not dropping to 0V? Are you sure GP1 is now configured as an input? |
I have removed #use_fastio(a) and all references to GPIO. Someone said that the pins on the IC are configured default for input until I use them as output. Correct me if I am wrong please. Thanks. |
GoldServe
Posted: Thu Jun 30, 2005 8:30 pm |
| Ttelmah wrote: | | GoldServe wrote: | | How i'm measuring it is from the time I turn the PIC on, I count 3 seconds and the output from the LDO goes high to ~3V. When I count another 3 seconds, I'll see the voltage try to dip to 2.8V and then go back to 3V. |
Count?...
Have you tried a watch?.
A lot of people can count quite reasonably for reasonable intervals, but go '1', 'and2', 'and3' etc., And are a good half second 'early' on the first few counts. If you are 'counting' time, you need to use something like 'thousandand1', 'thousandand2' etc..
How has the internal timing 'tweak' value been stored/kept during reprogramming?. The internal RC oscillator, is normally pretty accurate, but this tweak value must be maintained if the oscillator is going to be reasonably accurate.
I think my programmer will program up to 3EE or something like that, just before the last address. I don't need a totally accurate time but within 50ms is good enough. |
GoldServe
Posted: Thu Jun 30, 2005 8:31 pm |
Count?...
Posted: Fri Jul 01, 2005 5:19 am |
| Quote: | | I'm using compiler version 3.200 | This version was not considered a stable version and many bugs have been solved in the first months after this release. I don't have your version so can't check the generated code for that version. Because of the many problems in that version I suggest you use the last stable version v3.191, or one of the newer releases.
| Quote: | | Someone said that the pins on the IC are configured default for input until I use them as output. Correct me if I am wrong please. | You are correct (as long as you don't call #use_fastio).
A small improvement would be to disable the weak-pull ups, for this chip they are enabled by default. The pull-up resistors will generate a small current through the led.
In your sample code you are only switching the led1 output. Make sure the other led port is initialized to an output with a logic 0. Otherwise that port will be an input with pull-up resistor activating the led driver. |
