what could cause a write_program_memory to fail?
Nick
PostPosted: Sun Jun 26, 2005 3:28 am     Reply with quote
I am using loader.c and the write_program_memory function will work in the ex_load.c , but that specific function fails in my software. using a 16f876a
i working on adding a bootloader and i have traced the failure to that function, it will lock up
here are my debug statements
               if (line_type == 0) {
               printf("storing data\n\r");
                  // Loops through all of the data and stores it in data
                  // The last 2 bytes are the check sum, hence buffidx-3
                  for (i = 9,dataidx=0; i < buffidx-3; i += 2)
                     data[dataidx++]=atoi_b16(&buffer[i]);
                  #if getenv("FLASH_ERASE_SIZE")>2
                     #if defined(__PCM__)
                        if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")-1)!=0))
                     #else
                        if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")/2-1)!=0))
                           erase_program_eeprom(addr);
                     next_addr = addr + 1;
               printf("before write\n\r");
               printf("addr = %ld , count = %u \n\r",addr,count);
                  write_program_memory(addr, data, count);
               printf("after write\n\r");
               else if (line_type == 4)
                  h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
here is my output
storing data
before write
addr = 0 , count = 16
(lock up)
it works in the example, but doesnt when loader.c is use in my software... very confusing.
Anyone have any ideas?
Nick
asmallri
PostPosted: Sun Jun 26, 2005 6:32 am     Reply with quote
Have you specifically told the compiler you are using the 'A' version of the chip? The A and Non-A versions use different algotithms for writing to program memory.
You are overwriting the reset and interrupt vectors. Was that your intention?
Regards, Andrew
Nick
PostPosted: Sun Jun 26, 2005 12:07 pm     Reply with quote
I tried 16f876a.h and 16f876.h and both of them lock up in the same place as i explain above, in the example given by ccs only 16f876.h works.. which is very odd since i have an A chip.
Any help would be greatly apperciated.
Nick
Nick
PostPosted: Sun Jun 26, 2005 12:24 pm     Reply with quote
looks like the problem has to do with interrupts. I guess disabled_interrupt takes a few cycles to complete?
Nick
asmallri
PostPosted: Sun Jun 26, 2005 6:40 pm     Reply with quote
Nick
No disable interrupts is a singe cycle instruction.
Regards, Andrew
