| MCLR problem?? |
Posted: Fri Jun 24, 2005 7:33 am |
Hi all, i am very new to PIC, and have got a small problem. I have got a PICF877A. I am, for now, trying to flash a LED. I have got a 4MHz resinator, and the MCLR pin is high with a 10k and a .1uf cap. I have check for +5 on MCLR and it is OK. When i power on, the LED just stays on. I can make the thing work by touching the OCS1 pin with my bare hand, but when i let go, it will stop. I have also used a 20MHz crystal and a PICF84A without much luck. Here is my code just incase i am doing somthing wrong.
#include <16F877a.h>
while (TRUE) {
output_high(PIN_A0);
delay_us(500);
output_low(PIN_A0);
delay_us(500);
Thank you very much
Mark Demczuk |
Posted: Fri Jun 24, 2005 7:53 am |
| The first thing I would do would be to change the delay_us to delay_ms since 500 us is .5 milliseconds - very fast. It would probably appear to be ON all of the time. |
Markdem
Posted: Fri Jun 24, 2005 8:08 am |
Thank you so much, i cant belive i did that. Set time to 2000 and it works
Mark |
Mark
Posted: Fri Jun 24, 2005 10:42 am |
| @4MHz you should be using XT instead of HS |
| Re: MCLR problem?? |
Posted: Thu Jan 26, 2006 2:27 am |
| Anonymous wrote: | Hi all, i am very new to PIC, and have got a small problem. I have got a PICF877A. I am, for now, trying to flash a LED. I have got a 4MHz resinator, and the MCLR pin is high with a 10k and a .1uf cap. I have check for +5 on MCLR and it is OK. When i power on, the LED just stays on. I can make the thing work by touching the OCS1 pin with my bare hand, but when i let go, it will stop. I have also used a 20MHz crystal and a PICF84A without much luck. Here is my code just incase i am doing somthing wrong.
while (TRUE) {
delay_us(500);
output_low(PIN_A0);
delay_us(500);
Thank you very much
Mark Demczuk |
rnielsen
Posted: Thu Jan 26, 2006 9:13 am |
The Guest phantom Quote poster has struck again....
One reason to get rid of Guest posting.  |
