Einly
read 10 bit ADC on PIC16f876 |
Posted: Sun Jun 19, 2005 9:50 pm |
Dear all,
Does anyone have an example of how to use the 10 bit adc on PIC16f876? Previously, I am using the ADC, but instead of 10 bit, I only read 8 bit. May I know how does the program look like, if I want to read all the 10 bits? Thanks. _________________ Einly |
valemike Guest
Posted: Sun Jun 19, 2005 10:08 pm |
For devices that do have the 10-bit resolution in the A/D, you simply type the following statement at the top of your .c file:
#include <18F2620.h>
#device ADC=10
#fuses MCLR,HS,WDT4096,NOPROTECT,NOLVP,NOXINST,PUT
Above, my statement ADC=10 means i want to use 10-bit A/D. If you wanted to use 8-bit A/D, then type ADC=8
-Mike |
valemike Guest
p.s. |
Posted: Sun Jun 19, 2005 10:10 pm |
If you want to make an A/D reading, you would store it in an "unsigned long" or int16:
unsigned long this_reading; // assumes ADC=10
this_reading = read_adc();
unsigned int this_reading; // assumes ADC=8
