Silver
| LCD with pic18F452 |
Posted: Mon Jun 13, 2005 2:19 am |
Thank you for helping me...But I can't still write anything on LCD display.
My schematic configuration is:
4bit data LCD are connected to port D of 18F452 (RD0,RD1,RD2,RD3)
Enable line on LCD is connected to RA5 of 18F452
RS and R/W are connected respectively to RD4 and RD5 of 18F452
How could I modify the source code that you have me linked?
Thank you again! |
chingB
Posted: Mon Jun 13, 2005 5:27 am |
This is what I did for my PIC18F452 with an LCD module connection.
LCD Pin PIC18F452 Pin
DB4 RD4
DB5 RD5
DB6 RD6
DB7 RD7
LCD_EN RD0
RW RD2
RS RD1
My Header File for LCD.H
#ifndef __LCD_H__
#define __LCD_H__
// LCD Pin Map Structure
typedef struct LcdPinMapStruct
int unusedA; // portA is not used
int unusedB; // portB is not used
int unusedC; // portC is not used
boolean enable; // PinD0
boolean rs; // PinD1
boolean rw; // PinD2
boolean dummy; // PinD3 is not used
int data :4; // higher nibble of portD is used for data lines
} LCD_PIN_MAP_STRUCT;
// LCD PortA Register Mapping
#if defined(__PCH__)
LCD_PIN_MAP_STRUCT LcdPinMapBits;
#locate LcdPinMapBits = PORTA_BASE
#else
#locate LcdPinMapBits = 0x05
// LCD Tris Structure
typedef struct LcdTrisMapStruct
int control :3;
int data :4; // higher nibble of PortD is used for data lines
} LCD_TRIS_MAP_STRUCT;
// LCD TrisA Register Mapping
LCD_TRIS_MAP_STRUCT LcdTrisMapBits;
#locate LcdTrisMapBits = TRISA_BASE
#else
#locate LcdTrisMapBits = 0x85
// set Tris on ports for LCD
#define SET_TRIS_LCD(x) \
LcdTrisMapBits.data = (x); \
LcdTrisMapBits.control = 0;
#define LCD_TYPE (2) // 0=5x7, 1=5x10, 2=2 lines
#define LCD_LINE_TWO (0x40) // LCD RAM address for the second line
#define XLAT_OFFSET (0x80) // Character Translation Offset
#define LCD_SIZE (16) // Allocated Buffer for LCD Module
// LCD buffer allocation
byte LCDbuff[LCD_SIZE];
// These bytes need to be sent to the LCD to start it up.
byte const LCD_INIT_STRING[4] = {0x20 | (LCD_TYPE << 2), 0xc, 1, 6};
// The following are used for setting the I/O port direction register.
#define LCD_WRITE 0 // For write mode all pins are out
#define LCD_READ 15 // For read mode data pins are in
// The following display a string at specified x,y position
#define LCD_DISPLAY(x,y,string) \
lcd_gotoxy(x,y); \
lcd_putc(string);
* Function Prototypes *
void lcd_init(void); // initialize LCD display
char lcd_getc(byte x, byte y); // get char from LCD display
void lcd_putc(char c); // put char to LCD display
void lcd_gotoxy(byte x, byte y); // set an x,y position
void lcd_send_byte(byte address, byte n); // send a byte to LCD display
void lcd_send_nibble(byte n); // send a nibble to LCD display
byte lcd_read_byte(void); // read a byte from LCD display
My Source File for LCD.C
* Driver for Common LCD Modules *
* lcd_init() Must be called before any other function *
* lcd_putc(c) Will display character (c) on the next position of the LCD *
* The following Parameters: *
* \f Clear Display *
* \n Go to start of second line *
* \b Move back one position *
* lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) *
* lcd_getc(x,y) Returns character at position x,y on LCD *
#include "Include\T-Keeper LCD.H"
* Read a Byte from LCD *
byte low, high;
SET_TRIS_LCD(LCD_READ); // set data pin to input state (read mode)
LcdPinMapBits.rw = 1; // set to rw to high (read mode)
#asm nop #endasm // delay for one-clock cycle
LcdPinMapBits.enable = 1; // set the enable pin to high
high = LcdPinMapBits.data; // get the data from LCD (high nibble)
LcdPinMapBits.enable = 0; // set enable pin to low
LcdPinMapBits.enable = 1; // set enable pin to high
low = LcdPinMapBits.data; // get the data from LCD (low nibble)
SET_TRIS_LCD(LCD_WRITE); // set data pin to output state (write mode)
return ((high << 4) | low); // return result
* Send Nibble to LCD *
LcdPinMapBits.data = n; // send a nibble to LCD
delay_us(2); // delay for 2uSec.
return;
* Send Byte to LCD *
LcdPinMapBits.rs = 0; // set rs pin to low
while (bit_test(lcd_read_byte(),7));
LcdPinMapBits.rs = address; // provide the address to write
LcdPinMapBits.rw = 0; // set rw pin to low (write mode)
lcd_send_nibble(n >> 4); // send high nibble to LCD
lcd_send_nibble(n & 0x0F); // send low nibble to LCD
return;
* Initialize LCD Display *
void lcd_init(void)
byte i;
SET_TRIS_LCD(LCD_WRITE); // set all ports to output state (write mode)
delay_ms(15); // make a 15mSec. delay
for(i=1; i<=3; ++i)
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0; i<=3; ++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
for (i=0; i<LCD_SIZE; )
LCDbuff[i] = 0; i++;
return;
* Gotoxy LCD Routine *
void lcd_gotoxy(BYTE x, BYTE y)
byte address;
if (y != 1)
address = LCD_LINE_TWO; // if not line1 set address to line2
address = 0; // set address to line1
address += (x - 1); // increment to next address (line1 or line2)
lcd_send_byte(0,(0x80 | address)); // send to address to write
return;
* LCD Display PutChar Routine *
if (c == '\f') // clear and write to line1
lcd_send_byte(0,1);
delay_ms(2);
return;
else if (c == '\n') // write to line2
lcd_gotoxy(1,2);
return;
else if (c == '\b') // backspace one position (line1 or line2)
lcd_send_byte(0,0x10);
return;
lcd_send_byte(1,c);
return;
* LCD Display GetChar Routine *
char value;
lcd_gotoxy(x,y); // provide a x,y position
LcdPinMapBits.rs = 1; // set rs pin to high
value = lcd_read_byte(); // get a byte from LCD at x,y position
return (value); // return the value
Hope this would help connect your LCD module to a PIC18F452. |
chingB
Posted: Mon Jun 13, 2005 5:28 am |
DB4 RD4
DB5 RD5
DB6 RD6
DB7 RD7
LCD_EN RD0
RW RD2
RS RD1
#ifndef __LCD_H__
#define __LCD_H__
#else
int control :3;
#else
lcd_gotoxy(x,y); \
lcd_putc(string);
byte low, high;
return;
return;
void lcd_init(void)
byte i;
for(i=1; i<=3; ++i)
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0; i<=3; ++i)
return;
byte address;
if (y != 1)
return;
lcd_send_byte(0,1);
delay_ms(2);
return;
lcd_gotoxy(1,2);
return;
return;
lcd_send_byte(1,c);
return;
char value;
chingB
Posted: Mon Jun 13, 2005 5:29 am |
DB4 RD4
DB5 RD5
DB6 RD6
DB7 RD7
LCD_EN RD0
RW RD2
RS RD1
#ifndef __LCD_H__
#define __LCD_H__
#else
int control :3;
#else
lcd_gotoxy(x,y); \
lcd_putc(string);
byte low, high;
return;
return;
void lcd_init(void)
byte i;
for(i=1; i<=3; ++i)
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0; i<=3; ++i)
return;
byte address;
if (y != 1)
return;
lcd_send_byte(0,1);
delay_ms(2);
return;
lcd_gotoxy(1,2);
return;
return;
lcd_send_byte(1,c);
return;
char value;
