Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
recieve data from Hyperterminal
Almasri
PostPosted: Thu May 26, 2005 9:20 am     Reply with quote
Hi
mny question today is the following:
i am trying to get input from the user using Hyperterminal is it possible..??
my program goes something like this
#include <16f877a.h>
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT,PUT, NOPROTECT
while(TRUE) {
printf("\r\nPlease type (b) for board or (o) for onboard LED's");
a=getch();
if (a=='b') {
printf("\r\nWise Choice Son");
.........etc
Now, i wanted to get from the user a (Char), but with hyperterminal i CAN'T type anything to the screen ...
so what is wrong with my procedure or what am i missing or is it right to use hyperterminal to get data from the user..
thank you very Much
Programmer
PostPosted: Mon Jun 06, 2005 8:27 am     Reply with quote
you should set your Flow control to NONE on the option screen in the Hyperterminal
hope this helps..
