jahan
How to ShiftOut and ShiftIN in CCS? (Like PicBasicPro) |
Posted: Mon May 23, 2005 8:52 am |
If I have a 2 wire device with CLK and DAT, can somebody show me a very simple example of sending data out using CCS C?
For example an LCD which only has CLK and DAT lines and I have want to show "Hello".
Thankx |
Mark
Posted: Mon May 23, 2005 10:56 am |
#define OUT_CLOCK PIN_B1
#define OUT_DO PIN_B2
void ShiftOut (int8 data)
output_low(OUT_CLOCK);
if((data&0x80)==0)
output_low(OUT_DO);
output_high(OUT_DO);
data <<= 1;
output_high(OUT_CLOCK);
jahan
does ShiftIN works the same way? |
Posted: Mon May 23, 2005 1:02 pm |
Thank you for your posting.
It's very clean & clear.
can I ask you if ShiftIN works the same way but backward? and can you post a sample for ShiftIN?
Thankx again. |
Mark
Posted: Mon May 23, 2005 1:57 pm |
Take a look at 74165.c in your examples folder |
bfemmel
Joined: 18 Jul 2004 Posts: 40 Location: San Carlos, CA.
Posted: Mon May 23, 2005 2:21 pm |
Quote: | Take a look at 74165.c in your examples folder |
Actually, 74165.c is in the Drivers folder on my setup with 3.224 so it may be there for you too.
- Bruce |
Mark
Posted: Mon May 23, 2005 2:46 pm |
You are correct. My mistake. |
rnielsen
Posted: Wed May 25, 2005 1:09 pm |
Just an FYI...
If you use
.................... if(!(data&0x80))
0028: BTFSC 06.7
002A: BRA 0032
instead of
.................... if((data&0x80)==0)
0028: MOVF 06,W
002A: ANDLW 80
002C: XORLW 00
002E: BNZ 0036
you will save two commands in case you are worried about speed. This was compiled for a 18F452.
Ronald |
Futterama
Posted: Tue Oct 18, 2005 7:05 am |
Code: | #define OUT_CLOCK PIN_B1
if((data&0x80)==0)
output_low(OUT_DO);
data <<= 1;
How does this code work? I don't see how every bit is clocked out in this code, it doesn't loop as far as I can tell.
And I can't find information regarding this line: "data <<= 1;"
What does that line do?
I can't make it work :-/ |
Mark
Posted: Tue Oct 18, 2005 7:10 am |
It should be in a loop
int8 i;
for (i=0;i<8;i++)
if((data&0x80)==0)
output_low(OUT_DO);
data <<= 1;
Quote: | And I can't find information regarding this line: "data <<= 1;"
What does that line do? |
same as
And if you don't know what << does, then it is shift left so the statement shifts 1 bit to the left. If you look at the driver files it will show you. |
Posted: Thu Oct 20, 2005 3:43 pm |
That code don't work right either.
If i send 0b10100100 I get 0b10100101. |
Futterama
Posted: Thu Oct 20, 2005 5:44 pm |
Sorry, my browser didn't log me in automatically.
I know what my problem was, I needed shift right, not shift left.
Thanks for you help anyways  |
Mark
Posted: Thu Oct 20, 2005 6:50 pm |
Anonymous wrote: | That code don't work right either.
Get it where? |
Futterama
Posted: Fri Oct 21, 2005 2:49 am |
Mark wrote: | Anonymous wrote: | That code don't work right either.
Get it where? |
Mark, my mistake, thought I got that out of OUT_DO, but I was wrong.
I fixed it to work with my program, and I thank you for your help, no need to dig into it further. |
