nader
| need a cost efficient 8 bit DAC |
Posted: Wed May 18, 2005 9:24 am |
could some one guide me for selecting a cost efficient 8 bit DAC
that needed single power supply. |
kender
Posted: Wed May 18, 2005 10:25 am |
My favorite is MAX517/MAX518. Single/dual channel, I2C interface.
If you want something really cost efficient, you could run PWM output into an RC filter. It will make a poor man's DAC. However, this approach is a lot less precise. |
DragonPIC
Posted: Wed May 18, 2005 12:25 pm |
| kender wrote: |
and monitor it with an ADC channel. _________________ -Matt |
kender
Posted: Thu May 19, 2005 3:09 am |
| Quote: | | and monitor it with an ADC channel. |
DragonPIC,
Could you post the code, which runs this closed loop?
Thanks,
Nick |
DragonPIC
Posted: Thu May 19, 2005 12:40 pm |
I guess I could scronge up the code I created for out HV PS. This was done on a small 12F675 and isn't the way I would do it on a larger PIC (with a PWM), so it wouldn't make such a good example. It pulses a switching circuit and the resulting voltage is read back from a voltage divider. The ripple is kept to a minimum by a cap. and the fact that I can vary how often I pulse it by reading the result back with the ADC.
Also, not my design so I wouldn't feel right posting the code. _________________ -Matt |
