PROBLEMS CCS 3.224
Goto page Previous  1, 2
PostPosted: Tue May 17, 2005 12:33 pm     Reply with quote
In Section 18.0 of the 18F4525 data sheet, on the upper right side
of the page, it says:
The pins of the Enhanced USART are multiplexed
with PORTC. In order to configure RC6/TX/CK and
RC7/RX/DT as a USART:
• bit SPEN (RCSTA<7>) must be set (= 1)
• bit TRISC<7> must be set (= 1)
• bit TRISC<6> must be set (= 1)
What is in your code ? This line:
set_tris_c(0x00);
Whenever you use a PIC module, you must read the data sheet
section on that module.
Tony
problems CCS 3.224 OR EUSART PIC18F4525?
PostPosted: Wed May 18, 2005 3:33 am     Reply with quote
Before i'm writing you ,
I have tried "set_tris_c(0xC0);" but the thing is not change!
The code DOESN'T WORK WITH 18F4525!
Could you you please try the code below?
Tony
#include <18f4525.h>
//#include <18f452.h>
#FUSES HS, NOPROTECT, NOPUT, NOBROWNOUT, NOWDT, NOLVP
#ZERO_RAM
#byte TXREG= 0xFAD
#byte RCREG= 0xFAE
#byte SPBRG= 0xFAF
#byte SPBRGH= 0xFB0
#byte BAUDCON = 0xFB8
#byte RCSTA = 0xFAB
#byte TXSTA = 0xFAC
#byte PIE1 = 0xF9D
#bit BRG16 = BAUDCON.3
#bit BRGH = TXSTA.2
#bit SYNC = TXSTA.4
#bit TXEN = TXSTA.5
#bit CSRC = TXSTA.7
#bit SPEN = RCSTA.7
#bit TXIE = PIE1.4
int indByte;
#int_tbe
void tbe_isr()
indByte ++;
TXREG=0x55;
BRG16 = 0;
SPBRG = 207;
SPBRGH =0;
SYNC = 1;
SPEN = 1;
CSRC = 1;
TXIE = 1;
while (TRUE)
//set_tris_c(0x00);
set_tris_c(0xC0);
enable_interrupts(INT_TBE);
TXREG=0x55;
indByte = 0;
while (indByte < 5)
TXEN = 1;
TXEN = 0;
disable_interrupts(INT_TBE);
Tony
PostPosted: Thu May 19, 2005 12:25 am     Reply with quote
I'm waiting an answer.
Tony
PostPosted: Thu May 19, 2005 12:26 am     Reply with quote
I don't have a 18F4525 to test the problem in hardware.
I'll look at the code tomorrow.
PostPosted: Thu May 19, 2005 4:17 pm     Reply with quote
My version of the PCH compiler (vs. 3.188) doesn't support the 18F4525,
so I can't compile the code and look for problems in the .LST file.
I don't want to upgrade PCH just to do tech support, so I guess I can't
help you on this.
PostPosted: Fri May 20, 2005 2:15 am     Reply with quote
First a repeat of my previous suggestion, use the 'code' button when posting code!!! This will ensure the formatting of your code is preserved, making reading a lot easier to us.
In v3.224 I compared the listing files for both the 18F452 and 18F4525. Differences are in the initialization and #zero_ram, but the differences are minimal and after checking the registers I don't see any reason for failure.
I suggest to start testing your design at the lowest level. The 18F452 is working, but this is no garuantee the 18F4525 will. Maybe some difference in the clock input is causing problems. What frequency are you running and at what voltage? What does your clock circuit look like, is it a crystal or a real clock generator?
Just create a small test program blinking a led and tell us the results.
Tony
PostPosted: Fri May 20, 2005 3:42 am     Reply with quote
Crystal 8MHz and Voltage = 3V
But, did you try the code???
PostPosted: Fri May 20, 2005 5:19 am     Reply with quote
No, I dont have an PIC18F4525. But have you tried this code?
I suspect that either you have a hardware problem or you are testing with other software than you are showing to us. It took you a very long time to come up with a compilable version....
Please try a very simple program that is only blinking a led and continue expanding from there until the program fails.
PostPosted: Fri May 20, 2005 10:44 am     Reply with quote
Voltage = 3V
18F4525 does not run at 3v.
According to the 18F4525 data sheet, the minimum voltage
is 4.2v for all frequencys (up to 40 MHz).
You must have 18LF4525 to run at 3v.
PostPosted: Sat May 21, 2005 7:29 am     Reply with quote
PCM programmer wrote:
Voltage = 3V
Good find PCM !
So I was right by suspecting a hardware problem. I checked the voltages for the PIC18F452 and these are the same, so either Tony was very lucky with the 18F452 working in his old design or he was using an 18LF452 and didn't give us the complete part number.
tony
PostPosted: Mon May 23, 2005 2:01 am     Reply with quote
I have got PIC18F452, PIC18LF452, PIC18F4525, PIC18LF4525.
MPLAB 7.11 (or MPLAB6.60) and CCS 3.224
The code is doesn't work with PIC18LF4525 and with PIC18F4525!
The code works badly with PIC18LF452 and with PIC18F452!
MPLAB 6.60 and CCS 3.177
The code works well with PIC18LF452 and with PIC18F452!
[/b]
tony
Page 2 of 2
