delay_ms() question
glenjoy
delay_ms() question
PostPosted: Thu May 12, 2005 11:05 am     Reply with quote
What timer module does delay_ms command uses?
Thanks.
PostPosted: Thu May 12, 2005 11:16 am     Reply with quote
No timers are used by the delay-functions. Timing is based on the number of instructions in a for-next-loop. The exact number of instructions in the loop is determined at compile time and depends on the clock frequency you specified in the #delay statement.
DragonPIC
PostPosted: Thu May 12, 2005 11:29 am     Reply with quote
Yep, no OS or anything with this compiler. Just counting instruction cycles.
-Matt
valemike
PostPosted: Thu May 12, 2005 1:26 pm     Reply with quote
Furthermore, since they are 'software' time delays, then if you want to delay_ms(5), you are guaranteed at least 5 ms of delay. If interrupts hit and you service them, then this adds on to your 5 ms. That's why i say "at least"
