RS232 printf - how do I send a hex value instead of ASCII
Goto page Previous  1, 2
densimitre
PostPosted: Sun May 01, 2005 12:08 pm     Reply with quote
WOW, thank you very much...its working
Bye
John_Lintern
PostPosted: Thu May 05, 2005 3:46 am     Reply with quote
Can I first thank everybody for the replies to my post.
The replies helped me to get my program working !
I am currently using the putc(0x1B) command which works fine.
However, I really need to send a string of raw hex values ?
For example, I am trying to send the folowing raw hex values...
Byte: 00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15
Data: 1E 00 0C D1 00 07 00 01 00 03 00 01 60 00 72 D5
To do this using the putc command I used an array and a for loop, like this....
int i;
int Array[16]={0x1E,0x00,0x0C,0xD1,0x00,0x07,0x00,0x01,0x00,0x03,0x00,0x01,0x60,0x00,0x72,0xD5};
for (i=0;i<=15;i++)
putc(Array[i]);
This does seem like an awkard and limited way to send a string of raw hex values though.
Is there a better method ?
PostPosted: Thu May 05, 2005 8:04 am     Reply with quote
Is this a constant array, or one that is going to contain variable data?.
If the former, you can use a 'trick' of the compiler, where if you hand a constant string to a function that expects to receive an integer, the compiler will automatically step 'through' the array sending the data one character at a time.
So, if you code:
char testmsg[]="This is a test message\n\r";
void puti(int chr) {
  putc(chr);
Then in when you wnt to send the array to the output, have:
puti(testmsg);
The compiler will do the whole thing for you.
The array can be set up using hex values, or text. The only limitation, is that you can't send '0', since this is seen as the end of string character.
For a variable array, stepping through it as you show, is the 'normal' approach.
Page 2 of 2
