TaiChipY
Posted: Fri Apr 22, 2005 8:57 am |
First of all thanx for honest answer ! , and sorry for so long replay!
I put all timeouts on the timer2 (added seconds count) and timer1 is now "stand alone". Both timers are working fine and correct but there is allways but :-)).
Becuse the timer 2 is set for switch debouncing i have small problems with "reading" button presses. If i set timer resets of timer2 to 5 the button presses are readed correctly but then i have problems with getting correct second count. If the value is set to 10 i get wright second timeouts but wrong button "read outs". So i try to "correct" this thru miliseconds counter but with no success.
Scenario:
Until no SecondButtonPress
loop welcome / timeout10Seconds
SecondButtonPress
Activate other functions / timeoutMinutes
Now im bit stuck here... I know i can put the timeouts in the main ( without timers ) but then i have this situation:
With counter ( timer2 ) i will be loosing some seconds after timeout
but i can correct this. If i put this in main then how to trigger the right value?.
I know that this is not the best explanation...but the main thing is i have to have right 10 seconds and 10 minutes countdown and sleep/wakeup used in this two parts.
Wakeup goes thru interrupt on change.
| Code: | //-------------------------------------------------
#use delay(clock=8000000)
#fuses HS, NOWDT, PUT, BROWNOUT
#define INTS_PER_SECOND 30 // 30.51
int hours=24
int8 int_counter, seconds=0, days=5, minutes=60;
#INT_TIMER1
void clock_isr() {
if(--int_count==0)
++seconds;
int_counter = INTS_PER_SECOND;
if(seconds==60){
seconds=0;
minutes--;
if(minutes==0){
minutes=60;
hours--;
if(hours==0){
days--;
hours=24;
int8 seconds_t10;
int8 minutes_t10=10;
int8 Miliseconds;
#int_timer2
void timer2_isr(void)
if (Miliseconds < 0xFF)
Miliseconds++;
if (Miliseconds==1000)
Miliseconds=0;
sek_t10++;
if (seconds_t10==60)
seconds_t10=0;
minutes_t10--;
main()
Miliseconds = 0;
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
setup_timer_2(T2_DIV_BY_4,(100),10);
//while(seconds_t10 < 10){output_high(PIN_B2)};
Let's go one part on the time.
I will send you other part of the code regarding the sleep but let's solve this timing, first...
Thank you in advance! TaiChipY |
