Emil Guest
Out of ROM, A segment or the program is too large |
Posted: Tue Apr 19, 2005 5:56 am |
Hi!
When I compile the compiler says that the program is too large but I know that it's not because I have counted the size of the functions and know that it will fit in the ROM. Now to the problem..I'm using a bootloader and the bootloader can not be changed. This bootloader do not write to some addresses witch is wrong so I have to keep the compiler from placing code in that area. There is free space in the segments but still the compiler trys to place code in the forbidden area or something. Here is the err file
@DIV88
Seg 00000-00003, 0000 left, need 0017
0000
Seg 00004-00044, 0000 left, need 0017
0000
Seg 00045-00047, 0003 left, need 0017
0000
Seg 00048-0011A, 0007 left, need 0017
0000
Seg 0011B-001FF, 00E5 left, need 0017
0000
Seg 00200-007FF, 0600 left, need 0017
0000
Seg 00800-0081F, 0010 left, need 0017
0000
Seg 00820-0082F, 000B left, need 0017
0000
Seg 00830-0083F, 000B left, need 0017
0000
Seg 00840-00B3F, 0300 left, need 0017
0000
Seg 00B40-00FFF, 01F2 left, need 0017
0000
Seg 01000-017FF, 0800 left, need 0017
0000
Seg 01800-01FFF, 07D9 left, need 0017
0000
As you can see there is space left in the segments but how can I tell the compiler to place @DIV88 in some segment that is free? There is plenty of room for @DIV88 in Seg 01800-01FFF why don't the compiler try to put it there?
Using CCS version 3.214 and a PIC 16F877A
//EMP |
steve.booth
Out of ROM Space |
Posted: Tue Apr 19, 2005 6:51 am |
I have seen this before, quite common really.
The problem is that the CCS compiler generates 'one big file' when you compile your code. If you know the hardware inside your PIC, e.g. say a pic16f876, although you have 8k ROM, you actually have 4 x 2k ROM, and your code (specifically a single function) will not span across the ROM memory pages. What you need to do is reduce the size of your function(s), (main doesn't count onviously). This can be done by splitting off functions specifically into subroutine calls rather than in-line , use the #SEPARATE directive infront of the function ( and it's prototype )
This will allow the compiler to fit the code mode efficiently. _________________ Steve |
steve.booth
Out of ROM Space |
Posted: Tue Apr 19, 2005 6:53 am |
steve.booth
Out of ROM Space |
Posted: Tue Apr 19, 2005 6:57 am |
steve.booth
Out of ROM Space |
Posted: Tue Apr 19, 2005 7:01 am |
treitmey
Posted: Tue Apr 19, 2005 7:59 am |
Steve, They have many brands of de-caffeinated coffee that are very tasty. |
Mark
Posted: Tue Apr 19, 2005 10:00 am |
There is also the option to delete or at least edit those multiple posts  |
Out of ROM Space |
Posted: Tue Apr 19, 2005 10:58 am |
This will allow the compiler to fit the code mode efficiently. |
Out of ROM Space |
DragonPIC
Posted: Tue Apr 19, 2005 11:26 am |
feeling like a broken record? _________________ -Matt |
