Driving a LED bar
Goto page Previous  1, 2
future
PostPosted: Sun Apr 10, 2005 4:21 pm     Reply with quote
So I guess this solution would be the best since it only uses 1 pin right?
It is all about to hook everything we need on a single PIC.
12 pins to control 8 7-segment displays and 20 leds is acceptable.
As I have read somewhere, the perfect design uses 0 parts.
Thank you for all posts, I think the problem is solved.
I'll buy the parts and build a PCB.
Charlie U
PostPosted: Sun Apr 10, 2005 4:25 pm     Reply with quote
Thanks Mark.
To all,
They are all good ideas. Since no one had presented an approach that that was what Future had asked for, I thought I'd take time out of my day and throw it out there. No one said one idea was better than another, that is Future's job to determine which is best for the application.
I'm done.
Humberto
PostPosted: Sun Apr 10, 2005 5:00 pm     Reply with quote
Mark wrote:
You are assuming this. 9 pins may be acceptable to the poster. He just didn't want to use 20. ................
Heck, if its about fewest number of pins, then I could stick another PIC on there and only use 1 pin to do 1-way communication. Then have the other PIC drive the LED's directly. So I guess this solution would be the best since it only uses 1 pin right?
Forgot to mention that he will need to use 1 PIN and 2 PICs!!
Ok Mark, you won. Congratulations.
I will not support a senseless discussion.
Humberto
Mark
PostPosted: Sun Apr 10, 2005 5:30 pm     Reply with quote
another pic means an additional pic so yes, 2 pics because 1+1=2
PostPosted: Mon Apr 11, 2005 12:34 pm     Reply with quote
MARK YOU ARE PATHETIC !!! Embarassed
Douglas Kennedy
PostPosted: Tue Apr 12, 2005 5:45 am     Reply with quote
This discussion focused on reducing the number of pins to get the job done. Once other external components are introduced, it is natural to also consider an additional PIC as one of the additional component solutions.
Mark's knowledge has been and is a great asset to this board. Flamming is rude but if it has to happen it should at least wait till he is wrong. I suspect it will be a long wait. Hope this doesn't discourage Mark since I still have a lot to learn from him.
Mark
PostPosted: Tue Apr 12, 2005 6:10 am     Reply with quote
Bite me and quit using all the highlighting and underlining. It is annoying. BTW, nothing I said was incorrect. I can't help it if you are WRONG. Sorry, I couldn't resist. The thanks I get for trying to help some people out!
Mark
PostPosted: Tue Apr 12, 2005 6:24 am     Reply with quote
Thanks, at least not every one thinks I am that bad Smile
Page 2 of 2
