bunge Guest
Hardware rs232 hangs |
Posted: Fri Apr 18, 2003 5:55 pm |
I am probably violating some 'c' rule or other, or there may be a bug in the CCS compiler handling of the hardware RS232 on the 16C74. See below for programs communicating between two 16C74 via the hardware RS232.
The situation is:
1. If I send the same number of characters as I try to receive then the program works. However..
2: If I send less characters than I expect (as shown) then the programs behave as would be expected initially. The receiving end sits in the getc function waiting for the last character
to arrive. If the 'reset' button is pressed a second time to send a second burst of characters the display loop completes. If I press the 'reset' button again the receive program hangs in the getc loop no matter how many times the button is pressed.
3. By using various outputs to my LED array on port b I see that one byte of garbage is received on power up, hence my use of the a to get attention at the correct moment. I was
attempting to send binary data (not characters) between two pieces of equipment and simplified my problems down to this level when I was getting errors.
I think I have to either convert to hex, transmit, then convert to bytes - or - write my own RS232 code to use the status and control registers. I suspect an error bit (overrun or framing) needs to be cleared although with the delays I used I can't see why the program should hang.
I regard myself as experienced in electronics but only a novice C programmer.
// 16C74 at transmitter end - partial code...
#use RS232 (baud=9600, parity=N, bits=8, xmit=pin_c6, rcv=pin_c7)
main()
#define reset (input (pin_B6))
int i;
if (!reset){ // if reset pressed then send
putc ('a'); // send an a to get attention at the other end
for (i=1; i<=27; i++) {
putc (0x40 + i); // send A thru the next 26 codes to keep ASCII
delay_ms (1); // but putc (i) doesn't work either
} // end for loop
while (!reset); // wait for button to be released
} // end if loop
delay_ms (2000); // wait 2 seconds
} // end main loop
// 16C74 at receiving end - partial code...
main()
char data [30]; // declare array
int i;
while (1) // loop endlessly
while (getc() != 0x61); // wait for start character
for (i=1; i<=28; i++) { // 27 works, 28 does not
data [i] = getc(); // get data into array
} // program hangs in this loop
for (i=1; i<=28; i++) { // display data on LEDs
output_b (data[i]); // each for 1/2 seconds
delay_ms (500);
delay_ms (3000); // wait 3 seconds
___________________________
Original Post ID: 13796 |
Re: Hardware rs232 hangs |
Posted: Fri Apr 18, 2003 6:26 pm |
:=I am probably violating some 'c' rule or other, or there may be a bug in the CCS compiler handling of the hardware RS232 on the 16C74. See below for programs communicating between two 16C74 via the hardware RS232.
:=// 16C74 at receiving end - partial code...
:= #use RS232 (baud=9600, parity=N, bits=8, xmit=pin_c6, rcv=pin_c7)
It's about time to leave for the day, so I can give you one
quick tip. If you use the ERRORS directive, it will clear the
USART if an over-run error occurs. Example:
#use RS232 (baud=9600, xmit=pin_c6, rcv=pin_c7, ERRORS)
This only works with the hardware USART (which you are using).
Original Post ID: 13799 |
Humberto
Posted: Sat Apr 19, 2003 9:06 am |
:=The situation is:
:=1. If I send the same number of characters as I try to receive then the program works. However..
:=2: If I send less characters than I expect (as shown) then the programs behave as would be expected initially. The receiving end sits in the getc function waiting for the last character
:=to arrive. If the 'reset' button is pressed a second time to send a second burst of characters the display loop completes. If I press the 'reset' button again the receive program hangs in the getc loop no matter how many times the button is pressed.
:=3. By using various outputs to my LED array on port b I see that one byte of garbage is received on power up, hence my use of the a to get attention at the correct moment. I was
:=attempting to send binary data (not characters) between two pieces of equipment and simplified my problems down to this level when I was getting errors.
:=I think I have to either convert to hex, transmit, then convert to bytes - or - write my own RS232 code to use the status and control registers. I suspect an error bit (overrun or framing) needs to be cleared although with the delays I used I can't see why the program should hang.
:=I regard myself as experienced in electronics but only a novice C programmer.
:=// 16C74 at transmitter end - partial code...
:=main()
:= #define reset (input (pin_B6))
:= int i;
:= if (!reset){ // if reset pressed then send
:= putc ('a'); // send an a to get attention at the other end
:= for (i=1; i<=27; i++) {
:= putc (0x40 + i); // send A thru the next 26 codes to keep ASCII
:= delay_ms (1); // but putc (i) doesn't work either
:= } // end for loop
:= while (!reset); // wait for button to be released
:= } // end if loop
:= delay_ms (2000); // wait 2 seconds
:=} // end main loop
:=main()
:=char data [30]; // declare array
static int i, ch_rcved, packet_ready;
if(kbhit()) // IF falling down pulse in Rcv_PIN !!!
do
ch_rcved = getc();
if(ch_rcved == 0x61) // Start character
i = 0; //
i++;
if(ch_rcved == 'z') // last char expected
packet_ready = TRUE;
data[i] = ch_rcved; // store in buffer
}while(!packet_ready); //
if(packet_ready)
for (i=0; i<=27; i++) // display data on LEDs
delay_ms (500);
packet_ready = FALSE;
Be sure that the Rcv_PIN is glitch free, if necesary put a 10K pull up resistor.
Hope this help.
Humberto
Original Post ID: 13818 _________________ Humberto |
bunge Guest
Posted: Tue Apr 22, 2003 5:57 pm |
Thanks to everyone for the help. Yes, the problem was an input over-run, and yes the "errors" addition to the #use rs232... line solved the problem until I can write some more elegant code. Regards, Peter Bunge.
Original Post ID: 13931 |
