saving real time to an external eeprom
moataz
PostPosted: Sun Apr 20, 2003 3:57 am     Reply with quote
i want to write the current real time to an 24LC256 serial EEPROM what will be the code i need to??
Thanks.
___________________________
Original Post ID: 13829
Neutone
Re: saving real time to an external eeprom
PostPosted: Mon Apr 21, 2003 8:22 am     Reply with quote
:=Hello,
:= i want to write the current real time to an 24LC256 serial EEPROM what will be the code i need to??
:=Thanks.
Look in the forum for RTC to see a discussion of real time clocks. I assume your trying to figure out how to segment the time into bytes?
Original Post ID: 13864
Moataz
PostPosted: Tue Apr 22, 2003 10:48 am     Reply with quote
:=:=Hello,
:=:= i want to write the current real time to an 24LC256 serial EEPROM what will be the code i need to??
:=:=Thanks.
:=Look in the forum for RTC to see a discussion of real time clocks. I assume your trying to figure out how to segment the time into bytes?
Like this in binary:
write_ext_eeprom(0, hours);
write_ext_eeprom(1, minutes);
write_ext_eeprom(2, seconds);
Or in ASCII:
for(i=0;i<=strlen(time);i++)
write_ext_eeprom(i, time[i]);
Original Post ID: 13924
