KeithWard Guest
| Problems with printf or INT/INT8 |
Posted: Mon Apr 21, 2003 8:34 am |
I have had some difficulty lately with either int or int8 acting like a 7 bit or a signed 8 bit when using printf with an LCD.
I will get the correct values up to 127, after that the values switch to -128 and then work back to 127 for the full count of 255. I have tried similar experiments with just lcd_putc without the same problem yet I have not found any similar problems posted on this forum with this specificity.
Why is this happening? The code is *very* simple ...
Disclaimer:
I am citing this code from memory and not pasteing the *actual* code so any typos should not necessarily be construed as the *real* problem.
void main () {
int i=0
while (TRUE) {
for (i=32;i<256;i++) {
printf (lcd_putc,"Char Dec Hex\n");
printf (lcd_putc,"\%c \%d \%X",i,i,i);
delay_ms (1000);
lcd_putc("\f");
} // End For
} // End While
} // End Main
___________________________
Original Post ID: 13865 |
R.J.Hamlett Guest
| Re: Problems with printf or INT/INT8 |
Posted: Mon Apr 21, 2003 8:50 am |
:=I have had some difficulty lately with either int or int8 acting like a 7 bit or a signed 8 bit when using printf with an LCD.
:=I will get the correct values up to 127, after that the values switch to -128 and then work back to 127 for the full count of 255. I have tried similar experiments with just lcd_putc without the same problem yet I have not found any similar problems posted on this forum with this specificity.
:=Why is this happening? The code is *very* simple ...
:=Disclaimer:
:=I am citing this code from memory and not pasteing the *actual* code so any typos should not necessarily be construed as the *real* problem.
:=void main () {
:= int i=0
:= while (TRUE) {
:= for (i=32;i<256;i++) {
:= printf (lcd_putc,"Char Dec Hex\n");
:= printf (lcd_putc,"\%c \%d \%X",i,i,i);
:= delay_ms (1000);
:= lcd_putc("\f");
:= } // End For
:= } // End While
:=} // End Main
This is happening, because you are using the wrong qualifier in the printf statement. \%d, tells the function to expect a _signed_ integer. Hence the eighth bit will be treated as a sign bit. The qualifier to print an unsigned integer, is \%u...
Original Post ID: 13868 |
KeithWard Guest
Posted: Mon Apr 21, 2003 11:38 am |
Nice catch! So much for my memory of C and RTFM!
Thanks!
:=:=I have had some difficulty lately with either int or int8 acting like a 7 bit or a signed 8 bit when using printf with an LCD.
:=:=I will get the correct values up to 127, after that the values switch to -128 and then work back to 127 for the full count of 255. I have tried similar experiments with just lcd_putc without the same problem yet I have not found any similar problems posted on this forum with this specificity.
:=:=Why is this happening? The code is *very* simple ...
:=:=Disclaimer:
:=:=I am citing this code from memory and not pasteing the *actual* code so any typos should not necessarily be construed as the *real* problem.
:=:=void main () {
:=:= int i=0
:=:= while (TRUE) {
:=:= for (i=32;i<256;i++) {
:=:= printf (lcd_putc,"Char Dec Hex\n");
:=:= printf (lcd_putc,"\%c \%d \%X",i,i,i);
:=:= delay_ms (1000);
:=:= lcd_putc("\f");
:=:= } // End For
:=:= } // End While
:=:=} // End Main
:=This is happening, because you are using the wrong qualifier in the printf statement. \%d, tells the function to expect a _signed_ integer. Hence the eighth bit will be treated as a sign bit. The qualifier to print an unsigned integer, is \%u...
:=Best Wishes
Original Post ID: 13875 |
