ariza
| start/stop interrupt rountine |
Posted: Tue Mar 22, 2005 3:51 pm |
Hi all.
I am having some serious trouble with a very simple problem abut using interrupts.
In my program I use ext,ext1,ext2,timer0 interrupts and i want to enable and disable interrupts with ext2. In ext2 routine, if my program is working(a/d conversion in timer0 interrupt), it closes all interrupts. Also if my program is not working, it activates the program. Something like start/stop A/D conversion.
Firstly i use a variable in main part like "a" and give an initial value of a=1 and also in my other interrupt routines the value of "a" is "1". When program enters ext2 routine i write:
| Code: | #int_EXT2
EXT2_isr()
{ if(a==1)
{output_high(PIN_C1); //control led
a=0;
disable_interrupts(global);
pc=0;
if(a==0){
output_high(PIN_C2); //control led
enable_interrupts(global);
a=1;
pc=0;
And in main part
| Code: | for(;;)
{ output_high(PIN_C7); // control led
output_low(PIN_C7);
delay_ms(100);} |
Now is this the correct way??
Because when it enters ext2, program does not return to main part. There is no change in C7 led. Do I need to put break at the end of if parts.
And i want to cut other interrupts when Ext2 is active but also at the end of a==0 part in ext2 i want to activate forexample ext interrupt, so how can i set High/Low interrupt for ext2.
I know that if I set it high i can not activate another interrupt, is it correct ??
Note: in ext i take channel information
in i set sample rate
in timer0 A/D conversion
in ext2 start/stop my interrupts
Emrah |
ariza
Posted: Tue Mar 22, 2005 4:04 pm |
Hi all..
A correction : in notes part
| Quote: | | in ext1 i set sample rate |
thanks
Emrah |
Posted: Tue Mar 22, 2005 4:37 pm |
You must _never_ use enable_interrupts(global), inside an interrupt handler.
The interrupt hardware on the PIC, automatically disables the interrupts, when one is being responded to, _and re enables then, when the return from the handler code is executed_. By re enabling the interrupts before this point, you raise the possibility that an interrupt could interrupt an interrupt. The system can only save the registers once (which is done in the global interrupt handler), so if this happens, the original values will be lost, and the program will probably crash.
If you want to disable/enable the interrupts, set a flag in the handler, and have the main code do the disabling. You can quite happily disable/enable any individual handler inside the interrupts without problems (so 'disable_interrupts(INT_EXT', is fine).
Posted: Wed Mar 23, 2005 12:53 am |
OK!! thanks for advice. But my program main part(A/D conversion) is executed in timer0 interrupt nad I want to interrupt it and after Ext2 interrupt i don't need to return where the interrupt comes. The program starts to wait another ext2 to start the program again. How can i do this?
Best regards |
Mark
Posted: Wed Mar 23, 2005 10:43 am |
Not clear on what you are trying to do but you should set flags with the interrupts and handle your tasks in the main.
If you need to enable\disable global interrupts via a pin, then you will need to monitor those pins in the main loop. |
