using the A/D converter in the PIC16f874
Akhila
PostPosted: Sun Apr 20, 2003 4:53 pm     Reply with quote
The value I'm getting for the read_adc() is not what it is supposed to be. The range of Voltage inputing into PIN 2(A0) is 0v--5v.
input expected output actual output
0 0 0
0.5 26 103
1 51 209
1.5 77 52
2 102 161
2.5 128 5
3 154 113
3.5 179 210
4 205 64
4.5 230 154
5 256 255
My code also includes an 8bit counter 0--255, at 1 sec delay. It is supposed to print the correct value from read_adc(). Here is my code.
#include <16F874.h>
#use delay(CLOCK = 20000000)
int P7 = 0; // output most significant bit
int P6 = 0;
int P5 = 0;
int P4 = 0;
int P3 = 0;
int P2 = 0;
int P1 = 0;
int P0 = 0; // output least significant bit
byte value;
int ScanNumber =0; // declaration for number of scan times
int counter = 0; // counter for ten-minute time delay
void nextloop(void); // declaration for the 4 least significant bits
void delay(void); // declaration for ten-minute time delay
void Scan(void); // declaration for the 4 most significant bits
void dcvol(void); // declaration for printing the dc voltage
main ()
setup_adc(ADC_CLOCK_INTERNAL); // set clock for PIC
set_adc_channel(0); // set analog-to-digital input to pin2
setup_adc_ports(ALL_ANALOG);
for(ScanNumber=0; ScanNumber<9; ScanNumber++)
Scan();
delay();
void Scan(void)
for (P7=0; P7<2; P7++)
output_low(PIN_B7);
for (P6=0; P6<2; P6++)
output_low(PIN_B6);
for (P5=0; P5<2; P5++)
output_low(PIN_B5);
for(P4=0; P4<2; P4++)
output_low(PIN_B4);
if (P4 == 1) { output_high(PIN_B4); }
if (P5 == 1) { output_high(PIN_B5); }
if (P6 == 1) { output_high(PIN_B6); }
if (P7 == 1) { output_high(PIN_B7); }
nextloop();
output_low(PIN_B4);
output_low(PIN_B5);
output_low(PIN_B6);
output_low(PIN_B7);
void nextloop(void)
for (P3=0; P3<2; P3++)
output_low(PIN_B3);
for (P2=0; P2<2; P2++)
output_low(PIN_B2);
for (P1=0; P1<2; P1++)
output_low(PIN_B1);
for (P0=0; P0<2; P0++)
output_low(PIN_B0);
if (P0 == 1) { output_high(PIN_B0); }
if (P1 == 1) { output_high(PIN_B1); }
if (P2 == 1) { output_high(PIN_B2); }
if (P3 == 1) { output_high(PIN_B3); }
dcvol();
output_low(PIN_B0);
output_low(PIN_B1);
output_low(PIN_B2);
output_low(PIN_B3);
void delay(void)
for (counter = 0; counter < 120; counter++)
delay_ms(5000);
void dcvol(void)
value = 0;
value = Read_ADC();
printf("\%u\n\r", value);
___________________________
Original Post ID: 13841
Re: using the A/D converter in the PIC16f874
PostPosted: Sun Apr 20, 2003 5:36 pm     Reply with quote
:=The value I'm getting for the read_adc() is not what it is supposed to be. The range of Voltage inputing into PIN 2(A0) is 0v--5v.
<PRE>
0 0 0
0.5 26 103
1 51 209
1.5 77 52
</PRE>
Based on the number series above, you're getting 4x your
expected value, and it's being truncated to the lower 8 bits.
For example, 4 x 77 = 308.
and 308 - 256 = 52.
So you need to tell the compiler to return an 8-bit value from
read_adc(), instead of a 10-bit value.
So modify your pre-processor statements like this:
#include <16F874.h>
#device adc=8 // Add this line
If that doesn't fix it, then post the version of your compiler.
Original Post ID: 13846
