Douglas Kennedy
Posted: Fri Mar 18, 2005 5:27 pm |
I can see from the brochure that his GPS has both a TTL capability and an RS232 capability which clears up my mystery of how he can run both with his GPS.
He is using the TTL option for a direct( without a max232) connection to the PIC. I don't have the 18LF2620 data sheet but you can bet with the PIC18LF2620 running at 3v it is not using standard TTL for its logic levels. The GPS is running at 5V and probably sending standard TTL logic levels.
Its likely the GPS tx pin is creeping over the PIC 3v supply rail when sending a logic 1 and creating the issues newby is having.
PS VOM was short for Volts Ohms meter I should have used DVM oops. |
newby
Posted: Sat Mar 19, 2005 2:11 am |
It´s getting confusing more and more.
I´m using now an stable 8 MHz oscillator and an MAX driver between PIC and GPS unit. GPS and PIC running at 5V.
The level on RC7 (RX-PIC) changes from 0 to 5 V which should be OK.
Unfortunately it is still only garbage revceived.
I connected the GPS to the SIOW and everything worked fine, i connected the PIC to the SIOW and again everything worked fine, but if i connect the GPS to the PIC, only garbage...
Does anybody know an example how to use the auto baud rate mode ? |
Posted: Sat Mar 19, 2005 3:27 am |
Obvious comment.
If the 'level changes from 0v to 5v', does this imply the signal is idling at 0v?. If so, then the signal is inverted. The idle state for a TTL serial signal, is high...
newby
Posted: Sat Mar 19, 2005 3:37 am |
...before the driver the GPS signal idles at 3 V and changes to 0 V. After the driver the signal idles at 0 V and changes to 5 V.
Is this a problem ? |
Posted: Sat Mar 19, 2005 3:39 am |
Yes.
Instead of using the Max driver, look for a non-inverting level shifter. If the signal is the wrong polarity at the processor, you will not be able to use the hardware UART, and with the hardware UART, garbage will be the only result...
Posted: Sat Mar 19, 2005 7:17 am |
| For a quick test it should be enough to use the options FORCE_SW and INVERT to check this out. I will try and report... |
Douglas Kennedy
Posted: Sat Mar 19, 2005 9:20 am |
I'm not clear what newby is doing (if anything) to get his GPS into RS232 mode when testing using the PC port and SIOW.
Telemath has a good chance of being right in thinking that the TTL the GPS puts out is just a 0-5v volt version of RS232 in which case it is inverted and the hardware USART can't be used. A max232 costs a buck or two plus it provides substantial ESD protection for both the GPS and the PIC and probably would have avoided all the issues. |
