iso9001
| Need help w/ pic code to change RS232 Rates |
Posted: Wed Mar 16, 2005 1:05 pm |
Hi, using 16F876
I have a device that is setup to use rs232 on a non standard baud rate (7812.5) and need to convert that into something the PC can see.
I have no idea if someone makes a terminal that uses software "listening" to so that it can opertate at funny baud rates like this. That ofcourse would be the most practical, but I cant find anything like that.
My ideas are: Create a simple timer/delay/check system to monitor the lines, and then get the data in that way, then spit it out to the computer via hardware rs232.
Or if that gets two complex, split the load over two pics. Mabe use 1 for getting the non standard baud in and i2c it over to the other pic waiting to take data in and send it to the pc ?
I've not really used a ton of rs232 before so go easy on me
TIA |
SherpaDoug
Posted: Wed Mar 16, 2005 1:34 pm |
The CCS software UART can do any baud rate if the Xtal is fast enough. I would look at a chip with a hardware UART for the standard speed side, and a fast clock so you can do the odd speed in a software UART.
Does the odd speed change? Or can you measure it and write it into the code? Twenty years ago I worked on a product that had to deal with doppler shifted data sent acoustically. The baud rate could change noticably during a single message. That was a really complex software UART! _________________ The search for better is endless. Instead simply find very good and get the job done. |
iso9001
Posted: Wed Mar 16, 2005 1:40 pm |
No its steady 7812.5 baud. Its a stupid motorolla chip inside this thing. They like to use rates like that apparently.
I have some 20Mhz xtals here. You're saything this should be pretty easy using a single pic then ?
I'm in a time crush and having never coded rs232 and I only have 2 days or so to do this is going to suck. Havn't even seen how I pull a byte from the buffer yet.
I really wish someone just made terminal software to read in oddball rates. |
newguy
Posted: Wed Mar 16, 2005 1:49 pm |
iso9001,
Here is an example that I gave to one of my classes recently. It's pretty self-explanatory. It will help you get started.
| Code: | #include <18F452.h>
#device adc=8
#use delay(clock=4000000,RESTART_WDT)
#fuses XT, BROWNOUT, BORV20, PUT, STVREN, NOLVP
#include "i:\ELEN\LCD Task\lcd_driver.c"
// this program is based on one found in the text,
// "Embedded C Programming and the Microchip PIC",
// by Barnett, Cox, and O'Cull
#define RX_BUFFER_SIZE 80
#define TX_BUFFER_SIZE 80
int8 rx_wr_index = 0, tx_rd_index = 0, tx_wr_index = 0, tx_counter = 0, received = 0;
unsigned int8 rx_buffer[RX_BUFFER_SIZE + 1], tx_buffer[TX_BUFFER_SIZE + 1];
int1 data_avail = FALSE;
#int_RDA
void RDA_isr(void) {
rx_buffer[rx_wr_index] = getc();
rx_wr_index++;
if (rx_wr_index > RX_BUFFER_SIZE) {
rx_wr_index = 0;
data_avail = TRUE;
#int_TBE
void TBE_isr(void) {
if (tx_counter != 0) {
putc(tx_buffer[tx_rd_index]);
if (++tx_rd_index > TX_BUFFER_SIZE) {
tx_rd_index = 0;
tx_counter--;
if (tx_counter == 0) {
disable_interrupts(INT_TBE);
void bputc(int c) {
int restart = 0;
while (tx_counter > (TX_BUFFER_SIZE - 1));
restart = 1;
tx_buffer[tx_wr_index++] = c;
if (tx_wr_index > TX_BUFFER_SIZE) {
tx_wr_index = 0;
tx_counter++;
if (restart == 1) {
enable_interrupts(INT_TBE);
void main() {
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_ON);
setup_timer_0(RTCC_INTERNAL|RTCC_OFF|RTCC_8_bit);
setup_timer_1(T1_DISABLED);
enable_interrupts(INT_RDA);
//enable_interrupts(INT_TBE);
enable_interrupts(global);
set_tris_e(0);
lcd_putc("\f");
while (TRUE) {
restart_wdt();
if (data_avail) {
data_avail = FALSE;
received++;
if (received == 21) {
lcd_gotoxy(1,2);
else if (received == 41) {
received = 0;
lcd_putc("\f");
if (rx_wr_index == 0) {
lcd_putc(rx_buffer[RX_BUFFER_SIZE]);
bputc(rx_buffer[RX_BUFFER_SIZE]);
else {
lcd_putc(rx_buffer[rx_wr_index - 1]);
// echo is below
bputc(rx_buffer[rx_wr_index - 1]);
bluetooth
Posted: Wed Mar 16, 2005 1:52 pm |
iso:
I haven't tried it, but I notice that CCS's Port Monitor lets you set the baud rate to "other" - I entered 7812 in mine and it at least took it. Don't know if it works (might be PC dependent based on UART), but it might be worth a try....
Let us know if it works! |
iso9001
Posted: Wed Mar 16, 2005 2:17 pm |
Newguy: Thank Very Much! I looked through it quick and looks very easy to understand. I didn't look at the TX part too close so I'm not 100% on that but I just need to read instead of skim.
bluetooth: AH! You are the man! I'll try this out, its a good thing I got some max232s in as smaples awhile back Now why don't any other terminal software program do this ?
I'll try the software first as all I have to do there is set up a max232 and some wire. But If that doesnt work I'll have to build a pic setup as I just don't have the time for any crazy terminal software seraching |
SherpaDoug
Posted: Wed Mar 16, 2005 2:54 pm |
| iso9001 wrote: |
Terminal.exe available shareware at http://bray.velenje.cx/avr/terminal/ takes custom baudrates. It is my favorite terminal program. For the price (free) it is worth a try. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Humberto
Posted: Wed Mar 16, 2005 5:06 pm |
The original request:
| Quote: |
Hi, using 16F876
The following code is to start testing, it receives a non standard baud rate
and echoes using another port to the PC at 9600 Bauds . This code is
short and self-explanatory for starting purposes. Of course the deal is
using a ring buffer, but to implement that we need to know the
header/trailer character and/or how long the data stream zise is.
#include <16F876.h>
#device *=16
#fuses NOWDT,HS, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
#use rs232(baud=9600,parity=N,xmit=PIN_C6,bits=8,STREAM=PC)
#use rs232(baud=7912,parity=N, rcv=PIN_B0,bits=8,STREAM=MOTOROLA)
#zero_ram
#define YES 1
#define NO 0
static int8 data, char_rcved;
#int_EXT
void EXT_isr()
if(kbhit(MOTOROLA))
data = fgetc(MOTOROLA);
char_rcved = YES;
ext_int_edge( H_TO_L );
enable_interrupts(INT_EXT);
if(char_rcved)
fputc(data, PC);
char_rcved = NO;
hope this help,
Humberto |
Mark
Posted: Wed Mar 16, 2005 9:21 pm |
I'd just get a PIC with 2 UARTs on it. Or if it is okay, USB to the PC. |
