liche Guest
| Problems with code and simple output |
Posted: Fri Apr 18, 2003 6:02 pm |
I set up a very simple program to start experimenting with CCS C, but cannot get a simple LED to work. According to almost all the CCS C examples I've seen, it seems people are using the following command to turn an output on:
LED1 = ON; or LED1 = 1;
However, i am only able to get this thing to work if I use a line such as:
output_high(PIN_B2);
How do I configure the program to allow the use of the above examples such as simply writing, LED1 = ON; to enable the LED.
Here is the example program I was trying to write. If you could tell me what I'm doing wrong, I'd greatly appreciate it.
#include <16c66.h>
#fuses XT, NOPROTECT, NOWDT, NOPUT
#use delay (clock=4000000)
#byte PORT_A = 5
#byte PORT_B = 6
#byte PORT_C = 7
#bit LED1 = PIN_B2
set_tris_b(0b11000000);
while (TRUE)
LED1 = 1;
___________________________
Original Post ID: 13797 |
| Re: Problems with code and simple output |
Posted: Fri Apr 18, 2003 6:18 pm |
:=#bit LED1 = PIN_B2
The problem is in the bit statement. Try it this way:
#byte PORT_B = 6
#bit LED1 = PORT_B.2
Or, this would also work:
#bit LED1 = 6.2
Original Post ID: 13798 |
