v38zy
| SPI - No Data Signals |
Posted: Thu Mar 10, 2005 4:59 pm |
I am having serious problems trying to get the SPI to work. I have a PIC 18F4431 microcontroller, and the CCS C Compiler V3.212. All that I am trying to do is write some data out onto the SPI, but no data appears at the output (SD0) pin.
Currently I am using the default pins:
C3 = SCL
C4 = SDI
C7 = SDO
Using a scope, I have been able to determine the following:
1) The SCK signal IS present on pin c3, and is working correctly (i.e. outputs 8 clocks every time that I call spi_write).
2) The data out signal is always high (i.e. 5V), and does not change no matter what I write using spi_write().
3) If I try to use the alternate SPI pins:
D3 = SCL
D2 = SDI
D1 = SDO
then I don't even get the clock signal (on D3) anymore.
Here is the code that I am using:
C File:
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_16);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
spi_write(0xF0);
Header File:
#include <18F4431.h>
#device ICD=TRUE
#device adc=8
#use delay(clock=40000000)
#fuses NOWDT,WDT128,HS, NOPROTECT, IESO, BROWNOUT, BORV27, NOPUT, NOCPD, STVREN, DEBUG, NOLVP, NOWRT, NOWRTD, FCMEN, NOWINEN, T1LOWPOWER, HPOL_HIGH, NOWRTC, NOWRTB, NOEBTR, NOEBTRB, NOCPB, LPOL_HIGH, PWMPIN, NOMCLR, FLTAC1, SSP_RC
This seems like it could be a problem with the compiler.... but I have no idea why or what I can do to fix it. Does anyone know what I am doing wrong?
As well, if I connect the clock signal to the clock pin (C5) on another PIC which is configured as slave, the clock signal voltage drops from 5V peak to about 1V peak...
Thank you,
Andy |
Posted: Thu Mar 10, 2005 5:54 pm |
The first thing I see is that your #use delay() statement is set for 40 MHz,
but that implies that you're using either the 4x PLL mode (with a 10 MHz
crystal) or the external clock mode. But then you've got "HS" in your
#fuses statement. You would need either "H4" or "EC" instead.
My suggestion is, don't try anything fancy while in the early stages --
just run it at 10 MHz, in HS mode. Do this: #use delay(10000000)
Also, when you tried the alternate pins on Port D, did you remove the
"SSP_RC" fuse setting ? That setting puts the SSP pins on Port C. |
v38zy
Posted: Thu Mar 10, 2005 6:22 pm |
Thanks for the quick reply
I am using a development board which has a 40MHz crsytal on it, I can't change that. The clock is connected to the CLKI pin on the PIC.
I tried changing the fuse from HS to H4 and EC as you mentioned, but it didn't resolve anything. I even tried using the internal oscillator by setting fuse to INTRC and #use delay(8000000)... but I got the same result.
Yes, I did change SSP_RC to SSP_RD when I was trying to use the alternate pins on port D.
Any other suggestions?
Thanks,
Andy |
Posted: Thu Mar 10, 2005 6:31 pm |
Is the documentation for your development board available on the net ?
Can you post a link to it ? |
Posted: Thu Mar 10, 2005 6:39 pm |
No There is no documentation it is not publically available. It was built for the students to use at the University which I am attending.
There isn't much to it, it is just the PIC device, a power connector, the ICD connector, and a bunch of 10 pin headers which are connected to each of the ports on the PIC.
Andy |
v38zy
Posted: Thu Mar 10, 2005 6:40 pm |
| The previous post about the board was written by me... not sure why it shows up as Guest. |
Posted: Thu Mar 10, 2005 7:06 pm |
I don't have your version of the compiler, but I compiled the following
test program with vs. 3.188 and saw a problem with the TRIS setup.
Can you compile this program with your compiler, and post the .LST file ?
Then I can see if there's a problem.
When you post it, don't show your CCS user number. It's the number
right after the version at the top of the .LST file. Example:
CCS PCH C Compiler, Version 3.188, xxxxx
I don't know if giving that away makes it easier to for someone else
to logon and download the compiler, but why risk it ?
| Code: | #include <18F4431.h>
#fuses EC, NOPROTECT,PUT,BROWNOUT,NOLVP,NOWDT
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16);
spi_write(0xF0);
v38zy
Posted: Thu Mar 10, 2005 7:20 pm |
Ok, I compiled the program using the code that you provided. Here is the .lst file that was produced (minus the user number).
CCS PCH C Compiler, Version 3.214, xxxxx 10-Mar-05 21:16
Filename: C:\Documents and Settings\Andy\Desktop\Test3\Test.LST
ROM used: 50 bytes (0%)
Largest free fragment is 16334
RAM used: 5 (1%) at main() level
5 (1%) worst case
Stack: 0 locations
0000: GOTO 0004
.................... #include <18F4431.h>
.................... //////// Standard Header file for the PIC18F4431 device ////////////////
.................... #device PIC18F4431
.................... #list
.................... #fuses EC, NOPROTECT,PUT,BROWNOUT,NOLVP,NOWDT
.................... #use delay(clock=40000000)
.................... void main()
0004: CLRF FF8
0006: BCF FD0.7
0008: CLRF FEA
000A: CLRF FE9
000C: BCF FB9.0
000E: BCF FC1.6
0010: BCF FC1.7
0012: MOVLW 00
0014: MOVWF FB8
.................... setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16);
0016: BCF FC6.5
0018: BCF F94.5
001A: BCF F94.3
001C: MOVLW 21
001E: MOVWF FC6
0020: MOVLW 00
0022: MOVWF FC7
.................... while(1)
.................... spi_write(0xF0);
0024: MOVF FC9,W
0026: MOVLW F0
0028: MOVWF FC9
002A: BTFSS FC7.0
002C: BRA 002A
002E: BRA 0024
0030: SLEEP
Configuration Fuses:
Word 1: C400 EC IESO FCMEN
Word 2: 3E0E BROWNOUT NOWDT PUT NOWINEN WDT32768
Word 3: 9D3C T1LOWPOWER HPOL_HIGH LPOL_HIGH PWMPIN NOMCLR FLTAC1 SSP_RC
Word 4: 0081 STVREN NODEBUG NOLVP
Word 5: C00F NOPROTECT NOCPD NOCPB
Word 6: E00F NOWRT NOWRTD NOWRTC NOWRTB
Word 7: 400F NOEBTR NOEBTRB
Thanks,
Andy |
Posted: Thu Mar 10, 2005 9:35 pm |
There's a bug in the setup_spi() function. It's using the SCK and SDO
pins as if this was a 18F452. The problem is that in the 18F4431,
Microchip moved the SPI signals to different pins.
The code is setting up pins C3 and C5 to be outputs, and you really want
it on pins C5 and C7. So, the minimal fix would be to just set the TRIS
on C7 to be an output. See the revised test program below.
0016: BCF FC6.5
0018: BCF F94.5
001A: BCF F94.3 // *** Bug *** Should be F94.7
001C: MOVLW 21
001E: MOVWF FC6
0020: MOVLW 00
0022: MOVWF FC7
To fix this bug, add the lines shown in bold, below:
#use delay(clock = 4000000)
#byte TRISC = 0xF94
#bit SDO_TRIS = TRISC.7
SDO_TRIS = 0; // Bug fix: Configure the SDO pin as an output
spi_write(0xF0);
v38zy
Posted: Thu Mar 10, 2005 10:18 pm |
I can now see the data being sent out on C7!!! Thank you soo much, I was beginning to get pretty frustrated with this problem.
Is this the solution to the problem if I use the alternate pins on port D as well? Here is the .lst file if I add the fuse SSP_RD... Do you know what I should change?
CCS PCH C Compiler, Version 3.214, xxxxx 11-Mar-05 00:14
5 (1%) worst case
Stack: 0 locations
0000: GOTO 0004
.................... #fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP, SSP_RD
.................... #use delay(clock = 4000000)
0004: CLRF FF8
0006: BCF FD0.7
0008: CLRF FEA
000A: CLRF FE9
000C: BCF FB9.0
000E: BCF FC1.6
0010: BCF FC1.7
0012: MOVLW 00
0014: MOVWF FB8
0016: BCF FC6.5
0018: BCF F94.5
001A: BCF F94.3
001C: MOVLW 21
001E: MOVWF FC6
0020: MOVLW 00
0022: MOVWF FC7
0024: MOVF FC9,W
0026: MOVLW F0
0028: MOVWF FC9
002A: BTFSS FC7.0
002C: BRA 002A
002E: BRA 0024
0030: SLEEP
Word 1: C100 XT IESO FCMEN
Word 3: 993C T1LOWPOWER HPOL_HIGH LPOL_HIGH PWMPIN NOMCLR FLTAC1 SSP_RD
Thanks again,
Andy |
Posted: Thu Mar 10, 2005 11:53 pm |
| Quote: | | Is this the solution to the problem if I use the alternate pins on port D as well? |
The ASM code is wrong for Port D. It's setting TRIS for Port C.
The compiler isn't looking at the #fuse setting, in order to set the
TRIS for the correct port.
If you want to use either port, here's a more general solution, as shown
below. You just comment out the top #define statement if you want to
use port C for SPI, and un-comment it for Port D.
The TRIS settings for each port are now in constants, so you can easily
change them if you want to. If you use standard i/o (which is the default)
then you can use "output_low(PIN_D0);" for example, and the compiler
will set Pin D0 as an output without affecting the TRIS for the SPI pins.
#define SSP_PORT_D 1 // Comment out if using SSP on Port C
#ifdef SSP_PORT_D
#else
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP, SSP_RC
#endif
#define PORT_C_TRIS 0x5F // Port C SPI: Bits 5 and 7 must be outputs
#define PORT_D_TRIS 0xF5 // Port D SPI: Bits 1 and 3 must be outputs
// Fix the bug with the TRIS settings on the SPI pins.
#ifdef SSP_PORT_D
set_tris_d(PORT_D_TRIS);
#else
set_tris_c(PORT_C_TRIS);
#endif
spi_write(0xF0);
v38zy
Posted: Fri Mar 11, 2005 7:40 am |
Great! It works perfectly now
I really really appreciate your help PCM programmer, I never would have figured that problem out myself. People like yourself are what make these forums so useful  |
v38zy
Posted: Fri Mar 11, 2005 8:08 am |
One final question:
When I set up the slave, I assume that I will have to make similar modifications... Here is the .lst file for the slave, and I would like to use port D... Is there somewhere that I can get a listing of all the registers within the PIC so that I can make the necessary changes?
.................... setup_spi(SPI_SLAVE|SPI_SS_DISABLED);
0030: BCF FC6.5
0032: BCF F94.5
0034: BSF F92.5
0036: BSF F94.3
0038: MOVLW 25
003A: MOVWF FC6
003C: MOVLW 00
003E: MOVWF FC7
Thanks,
Andy |
Posted: Fri Mar 11, 2005 8:28 am |
The listing of all the registers (and LOTS of other good info) is found in the PIC datasheet.
You get the datasheet from the Microchip website: www.microchip.com |
Mark
Posted: Fri Mar 11, 2005 8:31 am |
| v38zy wrote: | One final question:
0030: BCF FC6.5
0032: BCF F94.5
0034: BSF F92.5
0036: BSF F94.3
0038: MOVLW 25
003A: MOVWF FC6
003C: MOVLW 00
003E: MOVWF FC7
Thanks,
Andy |
Goto Microchip's website and download the datasheet for that PIC. It has all the registers and even tells you how to setup the SPI without using CCS's functions. The problem that you are experiencing is the reason why I usually do not use the "special" CCS functions. They are prone to errors of this sort especially when support is added for the newer chips. Sometimes these functions save time but as you can see sometimes they make your life miserable. After coding for a while, you will develop a library of code snippets that you can reuse and you will find that reading the datasheet and understanding the chip will make you a more informed programmer. |
