Structures
Robert Carter
Structures
PostPosted: Fri Apr 18, 2003 12:44 pm     Reply with quote
I am trying to construct a 24-bit bit number, based on values of several variables of varying lengths, to be shifted out on an I/O pin. I get a "number out of range" error when compiling the following code. Is it possible to implement this type of structure? The Reference manual indicate only 8-bit values are allowed, but I have seen others using flot values.
struct RF_N
int8 RF_CTL_WORD : 3;
int16 C_WORD : 11;
int8 B_WORD : 2;
int8 A_WORD : 2;
int8 FRAC_CNTR : 4;
int8 CTL : 2;
} PLL_RF_N;
___________________________
Original Post ID: 13792
R.J.Hamlett
Re: Structures
PostPosted: Fri Apr 18, 2003 1:36 pm     Reply with quote
:=I am trying to construct a 24-bit bit number, based on values of several variables of varying lengths, to be shifted out on an I/O pin. I get a "number out of range" error when compiling the following code. Is it possible to implement this type of structure? The Reference manual indicate only 8-bit values are allowed, but I have seen others using flot values.
:=struct RF_N
:= int8 RF_CTL_WORD : 3;
:= int16 C_WORD : 11;
:= int8 B_WORD : 2;
:= int8 A_WORD : 2;
:= int8 FRAC_CNTR : 4;
:= int8 CTL : 2;
:= } PLL_RF_N;
You can use float values, but not with the length field descriptor. However you may be able to get what you require, by nesting a defintion, though how the actual data will be stored then falls into question. Unfortunately, at present, the bits will not wrap over into multiple bytes, meaning there will be 'gaps' in the data stored.
So you could define the variable with:
struct C_W {
int8 lo : 3;
int8 hi;
struct RF_N
struct C_W C_WORD;
int8 B_WORD : 2;
int8 A_WORD : 2;
int8 FRAC_CNTR : 4;
int8 CTL : 2;
} PLL_RF_N;
But this will occupy five bytes of memory, not four bytes.
Original Post ID: 13794
