Unable to Compile lcd.c
William Meade
PostPosted: Thu Apr 17, 2003 1:23 pm     Reply with quote
I am using a 2x16 display and a 16F877 and trying to run the ex_lcdkb.c program which uses the lcd.c. When I compile the program I get the following error.
"Unknown Type" and the word boolean is highlighted.
code snippet:
PRE
// As defined in the following structure the pin connection is as follows:
// D0 enable
// D1 rs
// D2 rw
// D4 D4
// D5 D5
// D6 D6
// D7 D7
// LCD pins D0-D3 are not used and PIC D3 is not used.
// Un-comment the following define to use port B
// #define use_portb_lcd TRUE
#DEVICE PIC16f877 *=16
struct lcd_pin_map {
boolean enable; // This is where error accours
boolean rs;
boolean rw;
boolean unused;
int data : 4;
} lcd;
/PRE
What do I need to do?
___________________________
Original Post ID: 13768
Dave Yeatman
Re: Unable to Compile lcd.c
PostPosted: Thu Apr 17, 2003 1:42 pm     Reply with quote
<font face="Courier New" size=-1>This is because BOOLEAN is not a standard type in CCS C. You have to put in either #define BOOLEAN short int -or- include the 16F877.h header file as the first line. You will also have to change the current first line to #device *=16
Dave
:=I am using a 2x16 display and a 16F877 and trying to run the ex_lcdkb.c program which uses the lcd.c. When I compile the program I get the following error.
:="Unknown Type" and the word boolean is highlighted.
:=code snippet:
:=PRE
:= // As defined in the following structure the pin connection is as follows:
:=// D0 enable
:=// D1 rs
:=// D2 rw
:=// D4 D4
:=// D5 D5
:=// D6 D6
:=// D7 D7
:=// LCD pins D0-D3 are not used and PIC D3 is not used.
:=// Un-comment the following define to use port B
:=// #define use_portb_lcd TRUE
:=#DEVICE PIC16f877 *=16
:=struct lcd_pin_map {
:= boolean enable; // This is where error accours
:= boolean rs;
:= boolean rw;
:= boolean unused;
:= int data : 4;
:= } lcd;
:=/PRE
:=What do I need to do?
:=Thanks</font>
Original Post ID: 13770
R.J.Hamlett
PostPosted: Thu Apr 17, 2003 1:43 pm     Reply with quote
:=code snippet:
:=PRE
:=// D0 enable
:=// D1 rs
:=// D2 rw
:=// D4 D4
:=// D5 D5
:=// D6 D6
:=// D7 D7
:= boolean rs;
:= boolean rw;
:= boolean unused;
:= int data : 4;
:= } lcd;
:=/PRE
:=Thanks
#include <16F877.h>
as the first line of your file.
Then do your 16 bit pointer defintion, as
#DEVICE *=16
Otherwise you will get an error saying that you cannot change the type this far into the code.
The include file, has th Boolean definition in it.
Original Post ID: 13771
PostPosted: Thu Apr 17, 2003 1:48 pm     Reply with quote
:=/PRE
Everyone else answered the main question before me, so I'll
mention one other item:
You're trying to use the PRE and /PRE tags, but they
didn't work. That's because you need to enclose them inside
"angle brackets". Here is a demo page that shows you how
to do it.
<a href="http://www.w3schools.com/tags/tryit.asp?filename=tryhtml_pre" TARGET="_blank">http://www.w3schools.com/tags/tryit.asp?filename=tryhtml_pre</a>
Original Post ID: 13772
whmeade10
PostPosted: Fri Apr 18, 2003 9:24 am     Reply with quote
Thanks to everyone who responded to my question. I have the LCD working perfectly with the 16F877.
Bill
Original Post ID: 13790
