PIC as I2C slave. HW problem
Goto page Previous  1, 2
Mark
PostPosted: Sun Mar 06, 2005 9:04 am     Reply with quote
Post the slave code EXACTLY as you have it.
fuzzy
PostPosted: Sun Mar 06, 2005 12:03 pm     Reply with quote
Slave:
#include <16f876.h>
#fuses XT,NOPROTECT,NOWDT,NOLVP,NOPUT
#use delay(clock = 4000000)
#define  PORT_A_TRIS_MASK        0x00   /* all outputs       */
#define  PORT_B_TRIS_MASK        0x00   /* all outputs           */
#define  PORT_C_TRIS_MASK        0x18   /* all  */
char prova;
char a=0;
char b=0;
char cambio=0b00000000;
int int_count=80;
char cambio1=0b00000001;
unsigned char read_i2c(void);
void i2c_interrupt_handler(void);
void i2c_initialize(void);
void i2c_error(void);
void write_i2c(unsigned char transmit_byte);
#INT_SSP
void ssp_interupt ()
    i2c_interrupt_handler();
#int_rtcc                          // This function is called every time
clock_isr()
{                                  // the RTCC (timer0) overflows (255->0).
                                   // For this program this is apx 15 times
    if(--int_count==0) {           // per second.
      cambio^=0b00000001;
      int_count=15;
/* 16f87X bytes */
/* Change it per chip */
#byte PIC_SSPBUF=0x13
#byte PIC_SSPADD=0x93
#byte PIC_SSPSTAT=0x94
#byte PIC_SSPCON1=0x14
#byte PIC_SSPCON2=0x91
/* Bit defines */
#define PIC_SSPSTAT_BIT_SMP     0x80
#define PIC_SSPSTAT_BIT_CKE     0x40
#define PIC_SSPSTAT_BIT_DA      0x20
#define PIC_SSPSTAT_BIT_P       0x10
#define PIC_SSPSTAT_BIT_S       0x08
#define PIC_SSPSTAT_BIT_RW      0x04
#define PIC_SSPSTAT_BIT_UA      0x02
#define PIC_SSPSTAT_BIT_BF      0x01
#define PIC_SSPCON1_BIT_WCOL    0x80
#define PIC_SSPCON1_BIT_SSPOV   0x40
#define PIC_SSPCON1_BIT_SSPEN   0x20
#define PIC_SSPCON1_BIT_CKP     0x10
#define PIC_SSPCON1_BIT_SSPM3   0x08
#define PIC_SSPCON1_BIT_SSPM2   0x04
#define PIC_SSPCON1_BIT_SSPM1   0x02
#define PIC_SSPCON1_BIT_SSPM0   0x01
#define PIC_SSPCON2_BIT_GCEN    0x80
#define PIC_SSPCON2_BIT_ACKSTAT 0x40
#define PIC_SSPCON2_BIT_ACKDT   0x20
#define PIC_SSPCON2_BIT_ACKEN   0x10
#define PIC_SSPCON2_BIT_RCEN    0x08
#define PIC_SSPCON2_BIT_PEN     0x04
#define PIC_SSPCON2_BIT_RSEN    0x02
#define PIC_SSPCON2_BIT_SEN     0x01
#define RX_BUF_LEN  2
#define NODE_ADDR   0x4e    /* I2C address of the slave node */
unsigned char slave_buffer[RX_BUF_LEN];
int buffer_index;
int comms_error;
int debug_state;
   /* Set up SSP module for 7-bit */
   PIC_SSPCON1 = 0x36;   /* 0011 0101 */
   PIC_SSPADD = NODE_ADDR;  /* Set the slave's address */
   PIC_SSPSTAT = 0x00;     /* Clear the SSPSTAT register. */
   enable_interrupts(INT_SSP);  /* Enable MSSP interrupts. */
    unsigned char i2c_mask = 0x2D;  /* 0010 1101 */
    unsigned char temp_sspstat;
    unsigned char this_byte;
    unsigned char tx_byte;
    int x;
    /* Mask out the unnecessary bits */
    temp_sspstat = PIC_SSPSTAT & i2c_mask;
    switch (temp_sspstat)
        /* Write operation, last byte was an address, buffer is full */
        case 0x09:   /* 0000 1001 */
            /* Clear the receive buffer */
            for (x=0; x<RX_BUF_LEN; x++)
               slave_buffer[x] = 0x00;
            buffer_index = 0;  /* Clear the buffer index */
            this_byte = read_i2c();   /* Do a dummy read of PIC_SSPBUF */
            debug_state = 1;
        /* Write operation, last byte was data, buffer is full */
        case 0x29:   /* 0010 1001 */
            /* Point to the buffer */
            this_byte = read_i2c();  /* Get the byte from the SSP */
            slave_buffer[buffer_index] = this_byte; /* Put it into the buffer */
            buffer_index++; /* Increment the buffer pointer */
            /* Get the current buffer index */
            /* Subtract the buffer length */
            /* Has the index exceeded the buffer length? */
            if (buffer_index >= RX_BUF_LEN)
               buffer_index = 0; /* Yes, clear the buffer index. */
            debug_state = 2;
        /* Read operation; last byte was an address, buffer is empty */
        case 0x0C:   /* 0000 1100 */
            tx_byte = slave_buffer[buffer_index]; /* Get byte from the buffer */
            write_i2c(tx_byte); /* Write the byte to PIC_SSPBUF */
            buffer_index++; /* increment the buffer index */
            debug_state = 3;
        /* Read operation; last byte was data, buffer is empty */
        case 0x2C:   /* 0010 1100 */
                buffer_index = 0; /* Yes, clear the buffer index */
            /* Get the byte */
            write_i2c(tx_byte);  /* Write to PIC_SSPBUF */
            debug_state = 4;
        /* A NACK was received when transmitting data back from the master. */
        /* Slave logic is reset in this case. R_W=0, D_A=1, and BF=0. */
        /* If we don't stop in this state, then something is wrong!! */
        case 0x28:   /* 0010 1000 */
            debug_state = 5;
        /* Something went wrong!! */
        default:
            i2c_error();
    a=slave_buffer[0];
    b=slave_buffer[1];
    buffer_index = 0;
    cambio1^=0b00000001;
    comms_error = 1;
    unsigned char write_collision = 1;
    while (PIC_SSPSTAT & PIC_SSPSTAT_BIT_BF) /* Is BF bit set in PIC_SSPSTAT? */
        /* If yes, then keep waiting */
    while (write_collision)
        /* If not, then do the i2c_write. */
        PIC_SSPCON1 &= ~PIC_SSPCON1_BIT_WCOL;  /* Clear the WCOL flag */
        PIC_SSPBUF = transmit_byte;
        /* Was there a write collision? */
        if (PIC_SSPCON1 & PIC_SSPCON1_BIT_WCOL)
            /* Yes there was a write collision. */
            /* NO, there was no write collision. */
            /* The transmission was successful */
            write_collision = 0;
    PIC_SSPCON1 |= PIC_SSPCON1_BIT_CKP;  /* Release the clock. */
/* This function returns the byte in SSPBUF */
    return PIC_SSPBUF;
  set_tris_a(PORT_A_TRIS_MASK);
  set_tris_b(PORT_B_TRIS_MASK);
  set_tris_c(PORT_C_TRIS_MASK);
  prova=input(pin_c3);
  prova=input(pin_c4);
    i2c_initialize();
    set_rtcc(0);
   setup_counters( RTCC_INTERNAL, RTCC_DIV_256);
    enable_interrupts(INT_RTCC);
    while (1)
if(cambio==0b00000001)
  output_high(pin_c1);
     output_low(pin_c1);
if(cambio1==0b00000001)
  output_high(pin_c2);
     output_low(pin_c2);
this is the exact slave code.
Page 2 of 2
