Guest Guest
| LCD problems |
Posted: Thu Mar 03, 2005 3:56 am |
Hi all. I seem to be having problems getting an lcd to work properly.
I am using a 1602 series lcd's 16*2 lines connected to port b. I am using the lcd driver provided by CCS. ( ver 3.207)
The lcd.c file in this version is slightly different from a previous one I used(unfortunately I can't remember the previous ver , I think it was 3.187)
With the previous version I did not have any problems...
The LCD structure is set up like this:
| Code: | struct lcd_pin_map {
int data : 4;
BOOLEAN enable;
BOOLEAN rs;
BOOLEAN rw;
BOOLEAN unused;
} lcd; |
With this structure the lcd WON'T work.
If I set up the lcd like this:
BOOLEAN enable;
BOOLEAN rs;
BOOLEAN rw;
BOOLEAN unused;
int data : 4;
} lcd;
Then the lcd works fine. Obviously I change the wiring to match the STRUCT!!!
With the previous version I could move the (DATA:4) , and rs , rw , e at will with no probs.
Any ideas what I'm doing wrong.
Cheers
Rob |
Mark
Posted: Thu Mar 03, 2005 6:59 am |
| Well I think I have 3.217 installed and the LCD.C file has a date of June 2003 so I do not believe they changed it. My guess is that you are not changing the LCD_READ and LCD_WRITE constants which control the tris registers. |
DavidHudd
Posted: Tue Mar 15, 2005 12:56 pm |
The reason it does not work is that the driver assumes the data nibble is D5-7 and does operations (e.g. on tris) without refering to the structure you modified.
You will need to do more extinsive changes to the driver or change the wiring. |
Mark
Posted: Tue Mar 15, 2005 1:22 pm |
| DavidHudd wrote: | The reason it does not work is that the driver assumes the data nibble is D5-7 and does operations (e.g. on tris) without refering to the structure you modified.
No way, the driver does not assume at all. None of the code has to be changed at all. Only as I said before | Quote: | | the LCD_READ and LCD_WRITE constants which control the tris registers. |
