Weird result on iButton search ROM
D-Kens
PostPosted: Mon Feb 14, 2005 10:16 am     Reply with quote
Hi...
I followed Dallas AN 187 about "1-Wire Search Algorithm" to write a Search_ROM function on a PICC 16F877. I finally wrote a working code (or so it seems) and tried to read the ROM code on a 1-Wire Weather Station from AAG : I should find a DS18S20, a DS2423 and a DS2450.
My function returns a 64 bit code for both DS2423 and DS18S20 (according to the family codes), but I only get the beginning of the 64 code for the DS2450. After a random number of bits read by the search ROM algorithm, function returns an error (no device participating in the search).
I doubt the problem is in the code, as it works fine for the two other components, but I'll try have a closer look to the logic anyway. Does anyone know if the DS2450 has particular needs ?! Or I might be interested in a 100% working Search_ROM function for my 16F877...
Thanks,
Christophe.
Douglas Kennedy
PostPosted: Mon Feb 14, 2005 5:14 pm     Reply with quote
I used this a few years back maybe it will be useful for you as a comparison to the code you wrote
#define dow_pin pin_b0
#bit    dow_pin_bit=6.0
char dev_id[8];
master_write_bit( short int send_bit)
 output_low(dow_pin);
     delay_us(10);
     if(send_bit)
        output_float(dow_pin);
        if(!dow_pin_bit) return(false);
        if(!dow_pin_bit) return( false);
     delay_us(50);
     delay_us(50);
void set_dev_id_bit(char *dev_id,int rom_bit_index,short int rom_bit)
// sets the bit referenced by rom_bit_index to the value
// on rom_bit
// rom_bit_index 0..63
int this_byte,value,this_bit;
this_byte=rom_bit_index / 8;
this_bit=rom_bit_index % 8;
value=*(dev_id+this_byte);
if (rom_bit==1)
   bit_set(value,this_bit);
   bit_clear(value,this_bit);
*(dev_id+this_byte)=value;
byte master_dow_search_rom(char *dev_id)
// for each bit of the unique 64 bit id that each device has
// the master reads twice and writes once
// on the first read each of the slaves repond with a specific bit
// on the second read  they send the complement
// the master then selects a value for that bit ( 0 or 1)
// slaves with that value stay in the process and the others go offline
// until the next reset
// since  any slave going low takes the line down for all
// the master  can see the following for each bit position in the id
// if slaves have 0 and 1 bits ..... 0 0
// if all slaves have 0        ..... 0 1
// if all slaves have 1        ..... 1 0
//          note:                    1 1 is an error
// master uses the 0 0 state to select among the slaves
// for the 0 1  state it sends 0 to keep all slaves for the next round
// for the 1 0  state it sends 1 to keep all slaves for the next round
// sent_bit_actual is not the bit from a single device
//  ( unless it is the only one still selected )
// but is the wire or value of the conflicting devices
// any device which is pulling low will win
short int sent_bit_actual,sent_bit_complement;
int rom_bit_index,last_discrepancy,marker;
last_discrepancy=0;
done=false;
next:
if(done)goto exit;
if( !master_reset()) return (false); // problem with wire
if( !master_read_presence())
     last_discrepancy=0;
     return(false); // no slaves detected
// now inventory the attached slaves
rom_bit_index=0;
marker=0;
master_write_byte(0x0f); // search rom command sent to slaves
read_dow:
sent_bit_actual=master_read_bit();
sent_bit_complement=master_read_bit();
if (sent_bit_actual==1 && sent_bit_complement==1)
    last_discrepancy=1;      // 1 1  something is wrong
    return(false);
if ( sent_bit_actual==0 && sent_bit_complement==0)
   if(rom_bit_index==last_discrepancy)
      set_dev_id_bit(dev_id,rom_bit_index,1);
   if(rom_bit_index>last_discrepancy)
       set_dev_id_bit(dev_id,rom_bit_index,0);
       marker=rom_bit_index;
           if (get_dev_id_bit(dev_id,rom_bit_index)==0)
else set_dev_id_bit(dev_id,rom_bit_index,sent_bit_actual);
master_write_bit(get_dev_id_bit(dev_id,rom_bit_index));
rom_bit_index++;
if(rom_bit_index<=63)goto read_dow;
last_discrepancy=marker;
if(last_discrepancy==0)  done=true;
exit:
return(true);
[color=darkred][/color][color=darkred][/color][color=darkred][/color][color=darkred][/color][color=darkred][/color][color=darkred][/color][color=darkred][/color][color=darkred][/color][color=darkred][/color]
D-Kens
PostPosted: Wed Feb 16, 2005 6:41 am     Reply with quote
Ok, thanks for your code, but I found the answer !!! As I suspected, the problem was not in my code but on the board itself. The DS2450 seems to need more power than the one provided only by the 1-Wire bus for complex operations like Search_ROM : that's why the function worked fine for reading codes of other components, but failed on that specific one. Confused
Added a capacitor to the board, to store some extra power when the line is high, and now I can read the ROM code of all 3 components that share the DATA line. Time for me to try and address each component individually now : wish me luck !!! May the Force be with me... Laughing
chrisdotronics
search rom for 1 wire device
PostPosted: Thu Mar 17, 2005 10:07 pm     Reply with quote
Hi!
I would you like your code (.c file full integral) to talking a wheather station ?
I tried but found just ds18s20 on wheather station??????
Thank!!!
