Baud Rate Error
Posted: Thu Feb 10, 2005 2:32 pm
The baud rate error is due to the baud rate being divisible into the clock speed. That is why I use 18.432MHZ instead of 20MHZ for example. Using 18.432 gives ZERO baud rate error.
In my most recent project I used a 9.216MHZ and enabled 4X PLL which gave me 36.864MHZ again with zero baud rate error. That is why many of the suppliers carry these seemingly "odd" frequencies in stock.
Posted: Thu Feb 10, 2005 6:06 pm
I find it most curious that when I go to Microchip's website and search for the PIC18F4620 that there are no errata sheets in the search results. There are for most other processors. If you check the document in the above post by cfernandez, it is 10 pages long!!! I wonder what other dirty little secrets, oops I mean errata sheets, are lurking in the weeds???
It might depend on how you are searching for the errata sheets. From the homepage I always go to the large table showing all PIC controllers of either PIC16 or PIC18-series. Then select the PIC18F420 and you get this page. In the table on the right side you will see 3 errata documents listed for different silicon revisions.
Page 2 of 2
