getc() not working at 16c745 well?
young
PostPosted: Thu Feb 10, 2005 3:34 pm     Reply with quote
I am using a getc() to get data from RS232 communication port. however, I could not make it work. following is the code
 while (TRUE)
      usb_wait_for_enumeration();
      while(usb_enumerated())
      printf("***Enumerated***\r\n");
    //  data=getc();
      putc('a');
if I did not mark off the data=getc()
the program just work for seval runs and stops.
any suggestions about this
young
PostPosted: Thu Feb 10, 2005 4:27 pm     Reply with quote
Here is the output. after three circles, it hangs there
0AWaiting for enumeration...***Enumerated***\0D
\0Aa***Enumerated***\0D
\0AInitialization!\0D
young
PostPosted: Thu Feb 10, 2005 4:29 pm     Reply with quote
No last line, it was for the init of the usb at the begining
like this
Give us something to work with!!
PostPosted: Thu Feb 10, 2005 4:31 pm     Reply with quote
Again the question we have asked you a number of times before:
How about showing us the code including the RS232 initialization. We are still not mind readers.
young
PostPosted: Thu Feb 10, 2005 4:38 pm     Reply with quote
Thank you: here is the full testing code
#define USB_PIC16C765 1 //set to 1 to use a PIC16c765 USB Peripheral
                        //set to 0 to use a National USBN960x peripheral
#if USB_PIC16C765 //use the PIC16C7x5 peripheral
 #include <16C765.h>
 #device *=16
 #fuses HS,NOWDT,NOPROTECT
 #use delay(clock=24000000)
#use rs232(baud=2400, xmit=PIN_C6, rcv=PIN_C7)
#endif
//Tells the CCS PIC USB firmware to include HID handling code.
#DEFINE USB_HID_DEVICE  TRUE
//Set this to FALSE if you only want to test enumeration.  Some USB test programs,
//such as USBCHECK, crash if you are trying to test enumeration and the device
//starts sending data once configured.
#DEFINE USB_RUN_WHEN_CONFIGURED  TRUE
//the following defines needed for the CCS USB PIC driver to enable the TX endpoint 1
#define USB_EP1_TX_ENABLE  1   //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_TX_SIZE    8   //if you change this, be sure to change the hid descriptor
//the following defines needed for the CCS USB PIC driver to enable the RX endpoint 1
#define USB_EP1_RX_ENABLE  1   //turn on EP1 for OUT bulk/interrupt transfers
#define USB_EP1_RX_SIZE    2   //if you change this, be sure to change the hid descriptor
#if USB_PIC16C765
 #include "pic_usb.h"   //Microchip PIC16C765 hardware layer for usb.c
#include "usb.c"        //handles usb setup tokens and get descriptor reports
#include <stdio.h>
#include <stdlib.h>
int8 length,i, status;
char datar[20],packet[8][10],data;
void main() {
   int i;
   //data number status (dnums) and data complete status (dcoms)
   char dnums,dcoms;
   puts("Initialization!");
   usb_init();
   printf("\r\n\r\nWaiting for enumeration...");
   SETUP_CCP1(CCP_OFF);
   SETUP_ADC_PORTS(NO_ANALOGS);
   while (TRUE)
      data=getc();
      putc('a');
      putc(data);
Possible Framing Errors
PostPosted: Thu Feb 10, 2005 4:51 pm     Reply with quote
OK,
The first thing I see is you dont have the ERRORS parm in the RS232 line so it can recover from framing errors:
#use rs232(baud=2400, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
See if that helps.
PostPosted: Thu Feb 10, 2005 5:54 pm     Reply with quote
thank you:
You are very sharp, even the data received is not correct most of times, it do keep running right now. maybe I need some delay for right reading.
Why is ERRORS so important.
PostPosted: Thu Feb 10, 2005 7:06 pm     Reply with quote
One thing I would do is use KBHIT to test the UART to see if a char is present before calling getc():
if (kbhit)
data=getc();
What is the source for the RS232 input to the PIC?
If the baud rate of the sender is far enough off then the PIC UART will encounter framing errors on the incoming data.
Without the ERRORS parm the UART will hang when the error occurs waiting for your program to perform a recovery.
With the ERRORS parm the recovery happens automatically.
PostPosted: Fri Feb 11, 2005 7:41 am     Reply with quote
I am simulating a serial input from another PIC. this PIC send data to TWS434 and received by RWS434 wireless board. this USB pic receives data from RWS434. I used 16f819 instead of USB pic, and I got everything function well. right now I want to use USB pic instead of 16f819. and then this problem happened. the boud rate is 2400.
PostPosted: Fri Feb 11, 2005 8:37 am     Reply with quote
Thank you dyeatman:
The kbhit() is good it solved the problem and right now it is output data correctly.
why in some chip it works fine without errors and kbhit() , but some, like 16c745 need it? what is the trap here?
PostPosted: Fri Feb 11, 2005 10:02 am     Reply with quote
Unfortunately without comparing the code for the other PIC and this one I am at a loss to explain it...but at least it works!!! One step forward!
dave
PostPosted: Tue Feb 22, 2005 7:15 pm     Reply with quote
what is wrong with this program? I put ERRORS, and used Khbit(), however, there is no output from the receiver side, some times just a dew space?
#if defined(__PCM__)
#include <16F819.h>
#include <stdio.h>
#include <stdlib.h>
#fuses HS,WDT,NOPROTECT
//#device ADC=10
#use delay(clock=10000000)
#use rs232(baud=2400, parity=N, xmit=PIN_A0, rcv=PIN_A1)
//sending
  char data[]="I am flying!";
   setup_port_a(ADC_OFF);
   setup_CCP1(CCP_OFF);
   setup_timer_1(T1_DISABLED);
   enable_interrupts(global);
     putc('X');
     delay_ms(200);
//receiving
#include <16F819.h>
#include <stdio.h>
#include <stdlib.h>
//#device ADC=10
#use rs232(baud=2400, parity=N, xmit=PIN_A0, rcv=PIN_A1,ERRORS)
  char data1[20],datar,ddl,ddh,datadecode;
  char status;  //data pre and post part
   status=0;  //lsb part
   datadecode=0;
   if ( kbhit() )
    {  datar = getc();
   //   delay_us(500);
      putc(datar);
    //  putc('a');
tahnk you
PostPosted: Wed Feb 23, 2005 8:13 am     Reply with quote
I do not know anyhow it starts working!
