theproff
| code example please |
Posted: Fri Feb 04, 2005 10:21 am |
Could someone give me an example on how to store an array of data to a fixed address in flash, this would obviously be const data..
thanks
theproff |
piedos
Posted: Wed May 18, 2005 1:59 pm |
const char array[]={a,b,c,d,e,f,g,h,i,j,k,l,m}; _________________ ---------------------------------------------------------
The only thing that equally given mankind is time. |
treitmey
Posted: Thu May 19, 2005 7:40 am |
This area is for POSTING code, not for ASKING for code. That being said.
| Code: | ///////////////////////////////////////////////////////////////////////////
#include <16F877.h>
#device *=16
#use delay(clock=16000000)
#fuses HS,NOWDT,NOLVP,
#use rs232(baud=19200,xmit=PIN_C4,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
#case
#zero_ram
#RESERVE 0x110:0x17F
int8 buffer[112];//bigest size of block in 16F877 16+80+16=112
#BYTE buffer=0x110
//======================= Main ==============================
int8 i;
fprintf(DEBUG,"Starting\n\r");
for (i=0;i<112;i++)
buffer[i]=i;
fprintf(DEBUG,"%u\n\r",buffer[i]);
See how I made a big array. Then the #byte says "store this variable at this location". ((This is also the technique to overlay variables on the physical pins of the PIC)) |
