young
| How to change the usb descriptor? |
Posted: Thu Jan 27, 2005 3:28 pm |
I am using the ex_usb_hid.c example from the ccs. the sample so far working fine.
I want to change the Transfer and Receive data bytes. I saw in the sample file, if I want to do that I have to change the usb description,
| Quote: |
#define USB_EP1_TX_ENABLE 1 //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_TX_SIZE 2 //if you change this, be sure to change the hid descriptor
//the following defines needed for the CCS USB PIC driver to enable the RX endpoint 1
#define USB_EP1_RX_ENABLE 1 //turn on EP1 for OUT bulk/interrupt transfers
#define USB_EP1_RX_SIZE 2 //if you change this, be sure to change the hid descriptor |
I want to the file provide by ccs, and find out the usb_desc.c file, but I do not know how to change it.
for example, if I want to
#define USB_EP1_TX_SIZE 20 ( this number is secret to me, what is the maximum number for me to define here
and
How accordingly, I should change the usb desceiption?
Thank you! |
young
Posted: Thu Jan 27, 2005 5:38 pm |
I looked into the usb_desc.h file and changed here
BYTE CONST USB_HID_DESC[] = { //len=28
6, 0, 255, // Usage Page = Vendor Defined
9, 1, // Usage = IO device
0xa1, 1, // Collection = Application
0x19, 1, // Usage minimum
0x29, 8, // Usage maximum
0x15, 0x80, // Logical minimum (-128)
0x25, 0x7F, // Logical maximum (127)
0x75, 8, // Report size = 8 (bits)
0x95, 2, // Report count = 16 bits (2 bytes)
0x81, 2, // Input (Data, Var, Abs)
0x91, 8, // Output (Data, Var, Abs) //changed to 8 original is 2
0xc0 // End Collection
after I compiled the program, windows could not recognize, and said this is a new device.
please help |
Posted: Thu Jan 27, 2005 9:53 pm |
| young wrote: | I looked into the usb_desc.h file and changed here
please help |
This is not correct.
It sounds like you need to read the USB spec. It's availble for free, do a google search. |
Posted: Fri Jan 28, 2005 7:31 am |
| any idea where and how I should change the USB descriptor or may be I do not even need to change, but how I can set more data instead of just 2 bytes a time. |
young
Posted: Fri Jan 28, 2005 9:52 am |
I found it, it should be
0x95, 2, // Report count = 16 bits (2 bytes) |
young
Posted: Fri Jan 28, 2005 10:23 am |
I did with the usb_put_packet(ep1,data,8);
how can i sent data message more than 8 for example 20,or 30 bytes,
I tried usb_puts(ep1,data,30,8,10);
I just received the first 8 bytes, I did not receieve the following bytes, why
did I use usb_puts wrong? |
Posted: Fri Jan 28, 2005 11:59 am |
| any suggestions? |
Posted: Fri Jan 28, 2005 1:47 pm |
| I found a solution by sending data packet by packet. anyway, I did not find out usb_puts working if any one success to do that, please let me know. |
