21 bit max ? !
Don P
21 bit max ? !
PostPosted: Tue Jan 25, 2005 6:39 pm     Reply with quote
I define a variable as int32.
Using "0b" binary notation to equate it to a constant, it won't compile if I specify more than 21 bits. Is this known?
Regards,
Don
rwyoung
PostPosted: Tue Jan 25, 2005 7:28 pm     Reply with quote
Can you post with your compiler version number and short (but complete) program demonstrating the issue?
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
Don P
PostPosted: Tue Jan 25, 2005 7:41 pm     Reply with quote
#include <16F628.h>
int32 X ;
void Main()
X = 0b11110000111100001 ; // add another digit and you get
// *** Error 76 "junk.c" Line 5(24,25): Expect ;
I used to know where to find the compiler ersion, but it's not apparent since it's combined with MPLAN 6.60
Tell me where.
Regards,
Don
PostPosted: Tue Jan 25, 2005 9:06 pm     Reply with quote
I used to know where to find the compiler version
There are at least three ways to find the compiler version.
1. Compile a test file, and look at the top of the .LST file.
It will show the version.
2. Click on Start/ Programs, and then find the entry for CCS.
It might be called "PIC-C". Then click on the icon for "Compiler Version".
2. Open a DOS window and go to c:\Program Files\Picc
and run this command line: CCSC +v
Don P
PostPosted: Tue Jan 25, 2005 9:35 pm     Reply with quote
Ah ha !
ver 3.152
dyeatman
works OK in 3.216 and 3.190
PostPosted: Tue Jan 25, 2005 10:04 pm     Reply with quote
Version 3.216 and both 3.190 work OK, no problem
Don P
PostPosted: Tue Jan 25, 2005 10:32 pm     Reply with quote
OK, unless it's a free upgrade, I can live with it.
