		| Author | Message |
		| prayami
				| ICD0161: Verify failed |
				|  Posted: Tue Jan 18, 2005 6:18 pm |   |
				| Hi..
 I got  CCS USB Development Kit for the PICmicro MCU.
 I was using Promate 2 previously for programming the PICs.
 But I think for this kit, I can't use Promate 2 so I have
 configured MPLAB ICD2.
 When I was trying the simple code(Turning LED On and Off) to program the 16F877A which
 is in this kit. Following happen.
 MPLAB ICD2 self test is passed.
 MPLAB ICD2 is connected successfully.
 Blank check is working.
 Erase device is working.
 Varify and Program is not working.
 But while try to program, in the varification time it is giving following error.
  	  | Quote: |  	  | MPLAB ICD 2 Ready
 Programming Target...
 ...Erasing Part
 ...Programming Program Memory (0x0 - 0x3F)
 Verifying...
 ...Program Memory
 ICD0161: Verify failed (MemType = Program, Address = 0x11, Expected Val = 0xF7, Val Read = 0xFF)
 ICD0275:  Programming failed.
 I have powered up the USB Kit circuit externally.
 I am using MPLAB ICD2 first time. But as other operations of connect, Blank check and
 Erase Part is working. We can say this is different problem...
 What can be the reason?
 Is it possible to have some problem in the Circuit Board?
 Here is the program which I am trying to load.
  	  | Quote: |  	  |
 #include <16F877a.h>
 #fuses HS, NOLVP, NOWDT, PUT, BROWNOUT
 #define GREEN_LED PIN_B5
 main()
 output_low(GREEN_LED);
 output_high(GREEN_LED);
		| PCM programmer
				|  Posted: Tue Jan 18, 2005 6:30 pm |   |
				| Try doing the "Connect" command in the MPLAB Programmer menu. Does it work ?   What messages does it give ?
		| prayami
				|  Posted: Tue Jan 18, 2005 6:40 pm |   |
				| It is connected successfully. There is no problem for connection, Erase Part or Blank Check.
 It is giving following message while try to "connect" from MPLAM
 Program menu.
  	  | Quote: |  	  | Connecting to MPLAB ICD 2
 ...Connected
 Setting Vdd source to target
 Target Device PIC16F877A found, revision = b4
 ...Reading ICD Product ID
 Running ICD Self Test
 ...Passed
 MPLAB ICD 2 Ready
 It is creating problem while try to program.
		| PCM programmer
