| How to get rid of warning when using _return_ feature? |
Posted: Thu Jan 13, 2005 1:53 pm |
I copied the find_parity() example from the Sept-2004 manual but can't get rid of the warning 'Function not void and does not return a value'.
I'm using PCWH v3.212 for the PIC18F458.
| Code: | #include <18F458.h>
#use delay(clock=16000000)
// This routine was copied from the CCS manual.
int find_parity(int data_char)
int count;
#asm
movlw 0x8
movwf count
movlw 0
loop:
xorwf data_char,w
rrncf data_char,f // use 'rrf' for pic16
decfsz count,f
goto loop
movwf _return_
#endasm
int8 data;
int8 parity;
parity = find_parity(data);
The above code is working and I do like the use of _return_, but how to get rid of the warning? |
Posted: Thu Jan 13, 2005 2:05 pm |
One way is to add this line to your program:
#ignore_warnings 208 |
Mark
Posted: Thu Jan 13, 2005 10:26 pm |
It will cost you a couple of bytes but:
#include <18F458.h>
int8 wreg;
#locate wreg = 0xFE8
int count;
#asm
movlw 0x8
movwf count
movlw 0
loop:
xorwf data_char,w
decfsz count,f
goto loop
// movwf _return_
#endasm
return wreg;
int8 data;
int8 parity;
Posted: Fri Jan 14, 2005 2:21 am |
Thanks PCMprogrammer and Mark, both your suggestions will remove the warning message.
I just don't like it that these are workarounds and have side effects. Use of the _return_ feature is documented in the manual so I feel like it shouldn't give a warning message.
For now I'll do with one of the workarounds AND post it to ccssupport. |
