Mark
Posted: Wed Jan 12, 2005 9:39 am |
| That just means that the hex file didn't contain the config word or "fuse" data as CCS calls it. By including the fuse statement in your C program, you can get rid of the warning. It is not a problem but rather a warning that you need to set them manually. |
Klaus Guest
Posted: Wed Jan 12, 2005 9:47 am |
Remove the statement
;PIC16F627
at the last line of your HEX file and it will work !!
I'm pretty shure of that.
Klaus |
Mark
Posted: Wed Jan 12, 2005 9:49 am |
| Anonymous wrote: | Ok, here is some info:
I use MPlab with CCS PCWH as compiler
I get the message "Wrong file format" when try to open the hex file generated by ccs with the programmer software from Velleman(K8084 kit)
I tried to remove the ;pic id here but it did not work. I tried all setting si could make with ccs. 8 bit, 16 bit and some of the others settings, but i do not exactly know what they do. Is it possible to post both hex files so you guys can take a look at it? |
He said he already did that! |
Posted: Wed Jan 12, 2005 10:10 am |
added #fuses HS,NOWDT,PUT,NOBROWNOUT.
Found this line looking in my old software. It all works now guys. Thanks for the help! |
