DS1307 Real Time Clock question
Goto page Previous  1, 2
PostPosted: Mon Jan 03, 2005 10:11 am     Reply with quote
Any code availabe?
Mark
PostPosted: Mon Jan 03, 2005 10:12 am     Reply with quote
How are you sending the data from the PC?
PostPosted: Mon Jan 03, 2005 10:16 am     Reply with quote
by uart serial port c6=tx and c7=rx
using keyboard to set the date & time.
Mark
PostPosted: Mon Jan 03, 2005 10:33 am     Reply with quote
Here are some snippets that will give you some ideas.
Here is a sscanf() function
http://www.ccsinfo.com/forum/viewtopic.php?t=20225&highlight=sscanf
buffer contains the time like say "13:45:12"
  int8 hour = 0;
  int8 minute = 0;
  int8 second = 0;
  int8 count = 0;
  if (isdigit(buffer[0]))
    count = sscanf(pArgs, "%b:%b:%b", &hour, &minute, &second);
    if (count >= 2)
      SetTime(hour, minute, second))
  return;
gca_ds1307_regs[DS1307_SECONDS_REG] = second;
gca_ds1307_regs[DS1307_MINUTES_REG] = minute;
gca_ds1307_regs[DS1307_HOURS_REG] = hour;
The same thing could be done for the date as well. You could do something like
"Enter the hours"
"Enter the minutes"
"Enter the seconds"
and use the gets() function to get the data and then convert that into a number using the atoi() function.
noisepic
wrong reading from ds1307
PostPosted: Mon Aug 15, 2005 8:03 pm     Reply with quote
hi Tullos!
I have used your code. I only display hour:minutes:seconds but they always 45:85:85
I check 3V battery- lithium--> OK
Check square wave out put--> OK
I used 16F84A, and PIN_B5 as SDA, PIN_B6 as SCL.
and in my display routine i use PORTB?
what's wrong?
Mark
PostPosted: Mon Aug 15, 2005 8:34 pm     Reply with quote
Are the lines pulled up to 5V with a resistor?
noisepic
PostPosted: Mon Aug 15, 2005 10:39 pm     Reply with quote
there is 1k pull up resitor to 5V , each pin SDA and SCL?
this project can work with 16F84?
noisepic
PostPosted: Wed Aug 17, 2005 4:28 am     Reply with quote
I'm looking for your reply. Anybody help me to find errors in hardware or program(the way for debug)? wrong reading time.
Sad
PostPosted: Wed Aug 17, 2005 5:59 am     Reply with quote
The time you read is equal to that of the first post in this thread, the problem there was a hardware problem. Please double check your battery connection (between ground and Vbat).
With the question mark '?' I'm not sure this is an answer or a question?
Yes, you need a pull-up on both SDA and SCL.
Can you tell us how you tested this? Can you make the DS1307 to output a 1Hz signal on this output? (change DS1307_CONTROL_REG_INIT_VALUE from 0x80 to 0x10).
noisepic
PostPosted: Wed Aug 17, 2005 8:57 am     Reply with quote
thanks ckielstra for your reply
I have measured PIN3 and GND by voltmeter. It's 3V
I wire both 1k pull up resitor on SDA and SCL PIN
I connect a Led on PIN 7 of DS1307 to GND. I see it flash (dim, not strong).
I have done it.
I double that i use PIN_B5 and PIN_B6 for SDA and SCL . I use PIN_B0,PIN_B1,PIN_B2,PIN_B3 for displaying on 7 segment led.
for ex PORTB=0x34.
In display routine i configure TRISB=0x00; // output
PostPosted: Wed Aug 17, 2005 10:09 am     Reply with quote
What is the voltage on pin8?.
The internal RAM is 'locked out', until this reaches _nominally_ Vbat*1.25. I had some problems with the device, when using a rechargeable lithium, that some examples were just not switching to allow the access, till the supply went over 1.3* Vbat.
Page 2 of 2
