int_tbe
Roland Koehler
int_tbe
PostPosted: Sun Apr 06, 2003 5:06 pm     Reply with quote
It seems to me that the #INT_TBE can't work; the emulator tells me that the flags necessary for this are not set (the INT_RDA is fine).
Has anyone used the transmit interrupt with async serial on 18F8xx parts? Or is there an example somewhere?
Maybe I just missed something...
___________________________
Original Post ID: 13453
Re: int_tbe
PostPosted: Mon Apr 07, 2003 12:30 pm     Reply with quote
:=It seems to me that the #INT_TBE can't work; the emulator tells me that the flags necessary for this are not set (the INT_RDA is fine).
:=Has anyone used the transmit interrupt with async serial on 18F8xx parts? Or is there an example somewhere?
:=Maybe I just missed something...
Test it with a real PIC, to help decide if it's a bug
in the emulator, or in the PIC or the compiler.
Errata for the emulator says there is a bug with the i2c BF
flag bit. So, there could be other bugs.
<a href="http://www.microchip.com/download/tools/picmicro/emulator/mpice/80078c.pdf" TARGET="_blank">http://www.microchip.com/download/tools/picmicro/emulator/mpice/80078c.pdf</a>
Original Post ID: 13468
