pulseout?
young
pulseout?
PostPosted: Wed Dec 29, 2004 5:19 pm     Reply with quote
Pulseout is a Basic language command , which is to generate pulse (10-us resoultion), I do know if there is related function in c language. I was also tried to simulated this function using the following code
output_high(PIN_A0);
delay_ms(1);  //delay time could be any numaber
output_low(PIN_A0);
is this correct?
PostPosted: Wed Dec 29, 2004 5:54 pm     Reply with quote
The source in ASM is available on this page:
http://www.piclist.com/techref/microchip/seepicsrc/index.htm
You could use the ASM code as a guide, and convert it to CCS.
PostPosted: Thu Dec 30, 2004 7:19 am     Reply with quote
Thank you PCM: would you help me to convert it to c, I know nothing about ASM?
PostPosted: Thu Dec 30, 2004 4:41 pm     Reply with quote
I think you should try to do it. It's better for you to learn
something than for me to do it for you.
